i have a 84 528e, and one day the windows stopped working, the sunroof still works, does anyone have any idea whats wrong?
All the windows? Check the fuses most likely.
you sure swap the swtich from your passenger side, if it still doesn't work, then is probably your wiring, or could be mechanical problem inside the door panel.
Check the curcuit breaker located on the right most part of the steering wheel surround. it should be a rectangle button in the middle of the panel. Try pressing the button and the windows should work again. This can easily be blown if you try rolling all your windows up at the same time and overload the window curcuit. HTH, and let me know if it works.
