i was checking out the acura tsx board and this is what i saw, someone had a dyno graph:
____________________________________________________-
Well the peak numbers are all essentially the same.
-----2.5L six-----------2.4L four
HP---170.1------------169.9
[email protected]@2800
Both HP numbers come essentially at redline.
If you do some calculation using a driveline loss of about 14% for both cars (pretty standard), you get at the flywheel:
-----2.5L six---2.4L four
HP---197.8----197.6
TQ---181.7----177.2
Which tells us that BMW's HP number was underrated (which I expected), and that the TSXs torque number was underrated (which we knew from the TOV review). So, the TSX has just under FOUR less lb-ft of torque, but it comes on at 700 RPM EARLIER (i.e. more low-end torque). It looks like the TSX torque curve is flatter, but that's due to the differing scales on these two charts. They're both about the same degree of "flatness".
HP---197.8----197.6
TQ---181.7----177.2
