So, my bimmer, 1992 318is, has never been a perfect vehicle, but here of late it's just taken the biggest, excuse my french, shit I've ever witnessed.
I guess I should start from the beginning.
I get in my car one day and turn the key, it delays for a bit and finally cranks up after much duress, I drive off and think nothing of it. Well the problem gradually progressed to the point to where one of three things would happen. One, absoloutely nothing happens, no cranking, no turning over, nada. Two, I'd hear clicking but no turning over. Three, the engine would attempt cranking and turn over endlessly with no results. I suspected the starter was going out but as I am military personell, I didn't really have the time or money to go and fix it. Well, I still needed a car, so I would push start the damn thing and pop the clutch. This worked for a while untill one fateful day, the engine would try to crank when I push started it, and then it would die.
I finally got some time to get underneath her and saw that the signal cable to the starter from the ignition switch had come loose and was missing a nut. I jerry rigged the contacts to the terminal and tried cranking it.... VROOOM. The engine started up however, it never became self sufficent. I had to keep the starter running and the throttle on full. If I let off on either, the engine died. This worked twice I believe. Now, even with the starter rigged, I get nothing. It's still not working... at all. To make the problem worse, hard to believe seeing as how I got so pissed off that I threw every tool I had at the time at the wall, the drivers side door latch quit working. My drivers side door is perminantly open. Great. I get super pissed off and go inside for the night. I come back to the project the next day and since the door was open all night and the following day, the battery was dead.
So, ladies and gentlemen, any advice, words of wisdom, or should I just go blow the thing up in the middle of the deasert and just watch her burn?
Respectfully yours,
Onepissedmarine:emo
Respectfully yours,
Onepissedmarine:emo
