Hey everyone having a few dramas here. My housemates beamer blew the engine so off to the wreckers they went and picked up a LH2, the 1 that we pulled out has LH6 on the block. I dont know too much about beamers but we started to do the swap.
everything on the engine was different from the aircon bracket to the wiring loom.
So what we did was change almost everything over. Weve used the loom from the LH6 onto the LH2 along with everything else like the top half of the manifold, the powersteering, aircon pump, ect ect, everything we had to change to make it work.
engine is now in and working fine along with the following problems......
when you turn the ignition on from a cold start the temp guage goes straight to halfway and then proceeds to go up from there. only other problem im having is the L/100k guage goes straight off the deap end as soon as you turn the motor on??????
Can anyone please help me with these problems it would be extremly appreciated.
Also there is 1 wire that we dont know where it goes which is on the part of the loom that goes just underneath this round thing right near the brake booster. ill get a pic of that too.
