I have a drivers side headlight short in the low beam wire that goes into a flat rubber insulated piece directly behind the low beam bulb... I can get the headlight to work when moving the wire. What is the piece that this wire feeds into and how do I fix the wire, remove the headlight assembly to get to it? thanks,
