I am having problems with my park/ tail lights staying on all the time. I had removed the some panels under the dash in preperation for a remote starter install. I think it is in the ribbon cable that feeds the light switch. From what I can figure out the park lights run on a constant ground and If I have a bad connection they will stay on. Can anyone confirm this?
Does anyone have any wiring schematic for the park lights on this vehicle or a possible cause of this problem. I took the battery cables off for 1/2 hour and then touched them together as advice by another mechanic, but it didn't help.
Any help would be appreciated!
Thanks!
Bad connection still need park light wire!!!
realoem.com starts X3 info at 2006
Found the problem. It was a bad connection in the ribbon cable leading from the light module to the light switch. There were a few wires that were not continuous from one plug to the other.
Now that I fixed the problem I have to find out which of these 10 wires in the ribbon cable is for the park lights to continue the remote install. I really don't want to take apart the plug connection and try the process of elimination. Does anyone know which wire controls park lights. I read a forum for another BMW and they were saying it was #7. Can anyone confirm this or save me from cutting it if it is wrong.
Thank You!
