hi
i am new to this forum , i have a warning light coming on , the indicator lamp with the triangle with the 3/4 circle around it
and it says drive control system drive moderately
does anyone know what this about
pleae help
thanks
if you just had it fixed, then your mech did not do a good job. Steering wheel angle sensor requires also that it be set & calibrated correctly.
What I meant was it happenED intermittently which is why I got it fixed. The dealer's work order showed that the cluster was replaced, programmed, and calibrated. I've had the car back for a week now and so far so good. No errors.
Balbs
