the car has 100 thousand miles on it, i have replaced the control arm bushings and the car drove good for a few mounths, now it is drifting with the road again, and the tires are wearing on the inside. Thinking about getting new struts would this fix the problem before i take it in for allignment, can't find any play anywere, also can the struts be put on after it is alligened.
Did you get a 4 wheel lazer alignment done after you changed the control arm bushings??, if you never this is why you have the problem and your tyres are wearing on the inside.If you did have it done I would suggest you take it back as they have obviously done it incorrectly..
