1 - 9 of 9 Posts
First time post!
Was hoping some of you guys with lots of experience in diagnosing Engine light problems could have a look at this and give me some idea where to start.
01 525i driving perfectly--no stuttering, starts every time--good performance when accelerating--cant feel anything wrong really but engine light on. 60,000 miles on clock.
Codes are as follows:
P0123: Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0228: Throttle/Pedal Position Sensor/Switch C
Circuit High Input
P0227: Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0202: injector circuit malfunction: Cylinder 2
P0203: injector circuit malfunction: Cylinder 3
P0238: Turbocharger Boost Sensor A circuit high
P0239: Turbocharger Boost Sensor B circuit malfunction
P0240: Turbocharger Boost Sensor B circuit range/performance
If this was all wrong surely it would feel like a tractor to drive?
Any ideas where to start -- GREATLY appreciated.
Thanks Guys
I also have no experience on error codes & scanner S/W. but I failed to understand the meaning of Turbocharged error messages in 525i. I would advise you to make sure that the scanner used in Bimmer specific & not generic one. I think this is important for correct diagnostic.
Meanwhile, a software reset or battery disconnection can resolve such issues sometimes.
Discussion Starter · #8 ·
Rashid--You were 100% right--Generic scanner producing irrelevant codes.
Ended up taking this to the local dealership.
They opened the bonnet and without scanning listened to it and said your breather cap or pipe is faulty.
They took it in and replaced the pipe and cap.--Reset the computer-no codes --driving like new.
Obviously they knew what to look for and this is perhaps something they have seen before....just posting for fututre reference for others.
1 - 9 of 9 Posts
