I have a 2000 328i that I bought a few months ago.
I took it to the dealer for an optional oil change and
supplied my own oil (Castrol Syntec 5W30). The owners
manual calls for approx. 6.5L or 7 qts of oil. I took in
6 litres thinking I would be topping off at home.
When I took it home, the dipstick showed the oil level
slightly past the upper notch. Does anyone know the
exact oil capacity? I watched the mechanic put only
the 6 litres in.
Joe G.
Welcome Moto! B)
you should always put less oil in than the capacity because not all the oil comes out when you drain it. for instance my car has a 4.3qt capacity but i only need about 3qts for a complete oil change. B)
Originally posted by MrM3@Jul 5 2003, 09:33 AM
Welcome Moto! B)
That really doesn't sound good. I've never had a car that didn't take the appropriate amount within .25 of a qt. 1.3qt is a big amount to not come out. =\
the 6 litres in.
Joe G.
Usually anywhere from 6-7 qts. you may have to add just a little bit later...
It also depends on if the oil filter has been replaced as well. The filter holds about half a quart of oil.
