:help Problem: Can't remove ignition key from ignition switch.
I can start the car, turn it off, use the accessory. When I try to remove the key from the iginition switch I can't get it out.
Anyone seen this problem or have a fix/suggestion on how to remove the key?
Thanks,
Pete:
you most likely have a bad tumbler you might try removing it then taking the key out.. then put the key back in the tumbler then back in the housing.. if you search in google how to remove ignition switch in e36 itl tell you
Captain... Savvy ?
Is it auto or Manual?
If auto, it could just be the Gear selector... Give it some force LOL
If Manual then it will be the barrel... Locating pin may be worn!
DAZ
