I recently bought a 97' 740i at auction with a known transmission problem: There is no action when the reverse gear is selected. And there is minimum action when the drive gear is selected. There are obvious transmission leaks. I haven't put it on a lift yet, but can tell from the oil on the floor.
I need some advice on how I should diagnose this issue. Look for leaks? Replace seals and gaskets? And try a transmission fluid flush? Or, does the Reverse gear not working at all indicate a failed transmission. Your advice is greatly appreciated. Thank you in advance.
42, The meaning of life
Welcome to the Werkz.
How many miles are on the car. It may be time to look at a change over gear box, or a rebuild. What color is the oil that is coming out of the gear box?
