The drivers seat adjusters on my 1995 540i decided to stop working along with the power steering wheel adjuster and the power mirror adjuster. The drivers heated seat still works and all adjustments on the passenger seat work. I've checked the applicable fuses. Is there a relay or other connection that I should look at?
Check the block connector is in properly under the seat......also look for a chaffed wire under there...
I know this thread is very old, but I am having the same problems and have been unable to fix the adjustment of my driver side seat. The seat is in a full reclined position. I have checked the fuses. Is there anything else I can do?
4DoorWhore
Power seat correct? Sometimes the gears of the seat motor break or come out of alignment. It's easy to fix but requires removal of the power seat motor.
