Help! I have a 1994 530i starts fine, but, when goes into idle starts to miss and check engine light comes on. Check engine light stays on and when mechanic uses computer to check codes it says oxygen sensor - already replaced both of those along with MAF, cold temperature sensor - anyone have any ideas?
Check for vacuum leaks as this lets additional unmetered air into the engine and the oxygen sensors cannot control it (that's why you get that code). It could be your intake manifold seals or your PCV (at the back of the intake manifold).
Second that ^ regarding hoses. Same issue with teh 740. Also replaced my fuel filters and she runs like a brand new sewing machine. Good Luck!
I am having the same idle issue on my 2000 528i... almost sounds like it wants to stahl out at times...
