hi i have had this problem for sum time now but its getting worse, the problem is sometimes when accelerating it seems to hold back a bit, if i drive it hard and let the revs go close to the limiter it will not run right after at all its like its running out of fuel, but if i turn the ignition of and on it will run fine, but then sometimes it will start running like a bag of poo, then the next minute its fine?
the other week i put redline in the fuel tank it ran mint for a few days, loads of power no problems at all, but then it started again, i have changed the plugs, and fuel filter, any help plez thanks.
also the other day when driving it did it that bad it had to be towed home, it was only just idling but when i put my foot down it would not rev up and it was backfiring and popping out the air filter?
