1st off, I'm a Honda guy. My sister has a 325ci for a while already and w/e, she mistreats the car like most women do... That being said, I want to start taking care of her car now that she allows me to. (I guess I got her trust by building my own engine and knowing how to do everything on MY car).
So I have a few questions:
1. What's the recommended oil to use and how much? She doesnt know, she just pays those rip-off Jiffy Lube and such companies..
2. Can I find the oil filter at Discount Auto parts/Autozone/Wal-Mart? I'm not really looking for Royal Purple quality (like i use in mine) but definitely NOT the cheapest crap out there either. Basically, does Fram/Purolator make oil filters for this car? (i'll find the p# once im there...)
3. I'm not gonna ask if it's easy or not to change the oil, but where can I find the instructions to do such thing? I know with Hondas, we have a 'Book' for each car and/or engine... and I know the bimmerz must have one too so where can I find it and/or can someone (if you have it) post that page or two which contains such info.
I'm pretty sure I got everything relating to tools, just trying to accquire the knowledge to work on those great handling german cars you all love. Thanks for reading.
1. Go with Synthetic. Which brands to use is a neverending debate. I used Mobil1 on my previous 3 Series and I have been running my E46 with Castrol syntec. I've always used 5w30, but I guess you can look into using something different depending on your climate.
2. Yes, you should be able to find teh filter in a parts store, but you'll pay triple for an STP/FRAM of what you would be paying for OEM brands like MANN/Mahle if you buy online. If you want to start maintaining this car to that it gets taken care of properly, I suggest you buy online.
3. The best book you will find is the Bentley Publishers E46 service manual. It will run about $100 or less on amazon, but it is worth it. It is still not a definitive guide, but you won't find anything better, particularly from Haynes or Chilton. The oil change is very simple. In fact it was much easier than changing the oil on my sister's Civic. For most tasks you can find a DIY online. Here is an example for teh E46 oil change: my 330i - Garage.
Welcome to bimmerwerkz!
P.S. I moved this to the E46 section
Thanks DRZ.
How many quarts does it take?
Another question I came across is, her (my sister) CEL is on due to the 'oil service w/e interval'.... how do I reset the ECU or what do I need to do to remove the check engine light?
I'll definitely purchase full synthetic oil. That's what I use on my car.... But what weight for her car that has 76k. We live in Miami, FL.... hot as hell so it can be a more viscous oil but give me a number please. As for the oil filter, we'll just get what we find at the auto parts store this time, but for next time, I'll definitely buy online... Online IS way cheaper.... Thanks for the help so far Bimmerwerks community!
I doubt the CEL is due to the oil service interval. Have the codes read at AUtozone or similar and we can go from there.
The DIY I linked to might have a procedure to reset the oil service interval light. All you need to do is HOLD the left odometer reset button WHILE turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done. Here it is in video form: Blogworthy
76k is nothing on that engine. It is barely broken in. I'd suggest you run the same eight you run on your car :dunno I ran 5w30 on my E36 with 220,000 miles living in Arkansas and I run 5w30 on my E46 with 60,000 living in Texas.
By the way, if you have a BMW dealershi nearby, they will probably charge as much for an OEM filter as Autozone will charge for a FRAM. I wouldn't even put a FRAM filter on teh Civic, btw.
Discussion Starter · #5 ·
hehehehe, I've done it a few times (in regards to the fram oil filter...) but for the past two years I just buy oem Honda filter in packs of 6 to save. I'll let you know tomorrow or sunday how my 1st exoerience with the bimmer went... Thanks again
Festivus yes, bagels no..
DRZ said everything I would have said. I personally use Mobile1 0w30, I've been wanting to use 5w30 but Wal Mart only ever has 0w30 when I'm about to change my oil.
One word of caution though, since the e46 has a canister filter make sure you don't over tighten the plastic cap. It cracks easier than you'd think...that's to blame for the giant oil stain on the floor of my garage...well, I guess I'm to blame. Now I ALWAYS use a torque wrench.
1. I use castrol 5w-40. Manual says you can 0w-X or 5w-X, where X indicates 30 and above
2. I dont think it is hard to change oil for E46. The drain plug is easy to locate since it is just sitting at the bottom of the oil tank. I did not use manual, and I just did it. I think there is a vid on youtube that shows you how to change oil for a E46.
Good luck man.
