Split PST Tool - BMW Forum - BimmerWerkz.com
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
post #1 of 12 (permalink) Old 04-27-2016, 05:30 AM Thread Starter
Jeffery Salas is on a distinguished road
Split PST Tool
Split PST Tool can select the PST file of large size from any location and divides it in several PST files of small sizes. It uses its own PST splitter to avoid the risk of corruption of PST files due to the issue of being over-sized. It also divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.It also supports all versions of MS Outlook like 2000, 2002, 2003 and 2010 and is fully compatible to Windows 2000, Xp, 2003, Vista, 10, 8.1, 8, 7.
Get details visit to: http://www.undeletepcfiles.com/split-pst-file.html
Jeffery Salas is offline
post #2 of 12 (permalink) Old 06-01-2016, 06:13 AM
cameronboyce is on a distinguished road
MS Outlook doesn't have a built-in function to split a .PST file to make the size smaller and manageable. Either you have to use "archive" feature to move PST items to new Outlook PST file or you have to "Move to Folder" feature. Otherwise, you can also use a tool for splitting large PST file: http://www.split-pst.com
cameronboyce is offline
post #3 of 12 (permalink) Old 03-24-2018, 02:53 AM
asmeet is on a distinguished road
Split PST Tool is an advance professional pst splitter tool embedded with a strong algorithm which can easily and efficiently split the large pst file into small pst files with the hundred percent accuracy of data.Split PST File Tool supports all versions of MS Outlook and is capable of splitting of PST files creates using MS Outlook 2000, 2002 (XP), 2003, 2007, 2010 versions.
Visit here:- datavare.com/software/outlook-pst-split-expert.html
asmeet is offline
post #4 of 12 (permalink) Old 10-23-2018, 07:13 AM
dainavoldmert is on a distinguished road
PST Splitter
PST Splitter software is a very robust & powerful tool that helps you split large Outlook PST files into smaller files as per requirement.
Salient features:
Fastest and Efficient for this process
Splits PST files by Size, Date, Email ID, and Folders
Splits PST files into smaller ones and prevents corruption
Preserves the structure of original PST files after splitting
Supports MS Outlook 2016, 2013, 2010, 2007 & 2003
For more info visit: completeconverter.com/split-pst/
dainavoldmert is offline
post #5 of 12 (permalink) Old 12-08-2018, 05:37 AM
peterparkar110 is on a distinguished road
Mailvita Split PST for Mac File software is excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. The software makes you sure that no actual data deleted during the process.This software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Mac.
peterparkar110 is offline
post #6 of 12 (permalink) Old 04-30-2019, 03:52 AM
cbdbfkjed is on a distinguished road
Split PST File software is excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion . This remarkable software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Windows. softakensoftware.com/split-outlook-pst.html
cbdbfkjed is offline
post #7 of 12 (permalink) Old 05-27-2019, 03:28 AM
priyankaarya is on a distinguished road
PST Split tool
If you searching for a tool which will help you to split large PST Files into smaller then this article will help you out in this there are some manual hacks and one of the best software for the issues. As we all know manual tricks are time-consuming and even data security is not there even a minor mistake can lead to data loss. so go with the tool-free demo version.
SysInfo PST Split
priyankaarya is offline
post #8 of 12 (permalink) Old 07-06-2019, 08:23 AM
william jos is on a distinguished road
pst splitter
If you are looking for a solution to Spit your oversized PST file then here is the best way to split them. The Outlook PST Splitter is an excellent utility software which provides the option to split oversized PST file as per the requirements of the users. This PST File Splitter Software provides an option to split PST file by specific Date & Time range. You can download this tool at FREE of cost.
[B]For more information about Visit here Outlook PST Splitter
william jos is offline
post #9 of 12 (permalink) Old 08-23-2019, 01:59 AM
Elenabloton is on a distinguished road
ToolsGround Split Outlook PST Software is an advanced tool that breaks large size PST file into smaller PST files as per the specific criterion. The tool performs a risk-free operation for splitting PST without making any change on original data.
More Info;- toolsground.com/split-outlook-pst/
Elenabloton is offline
post #10 of 12 (permalink) Old 12-10-2019, 02:27 AM
Harry Brown is on a distinguished road
Arrow Split PST Tool
Hello
The KDETools Outlook PST Splitter tool is one of the best PST Splitter tool which easily divides large PST files into small parts by date, size, year and folder. It is easily capable of ANSI and UNICODE Version. This tool split the large PST files without installing MS-Outlook. It split the large PST files without any changing original data. It split the large PST files in all Windows Version and Outlook Version. It is 100% safe and secure conversation.
Harry Brown is offline
post #11 of 12 (permalink) Old 01-14-2020, 01:58 AM
7john is on a distinguished road
Hello
Last Month I have phased the same problem due to large PST files My Microsoft does not work properly then my friend suggests me to try the PST Splitter to is KDETools PST Splitter. This tool easily solves or split my large PST files into small parts according to my needs by date, size, year and folder.
7john is offline
post #12 of 12 (permalink) Old 01-14-2020, 06:32 AM
jonasen is on a distinguished road
To Split or Break large size Outlook PST files in some small PST files here you will get the excellent solution. To Split, your Outlook PST files in some small PST files use Gaintools Split Tool of Outlook which allows user breaks the PST file in some small PST files by Date, Size and access all them as according to the current requirement. To get more information about Outlook PST Split Technique. The free trial version which transfers the first 10 items from each folder.
jonasen is offline
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Peake research tool - SRS reset tool, anyone around have them? 98three28i North East 0 06-26-2006 06:57 PM
New Split Forums....needed Or Not??? nerf26 5-Series (E12,E28, E34, E39, E60) 4 11-19-2004 05:42 PM
