BMW Forum - BimmerWerkz.com
BMW Forum - BimmerWerkz.com (https://www.bimmerwerkz.com/forum/)
-   Audio and Electronics (https://www.bimmerwerkz.com/forum/audio-electronics/)
-   -   1992 325i (E36) Amplifier wiring? (https://www.bimmerwerkz.com/forum/audio-electronics/1992-325i-e36-amplifier-wiring-15964.html)
speedbump 07-15-2004 09:37 PM
I have a '92 325i 4-door with 6 speakers up front and four (well, two, now that I've replaced the Nokia boxes with some particle-board-mounted 6-1/2" coaxials) in the back. The back speakers were easy to put in as the Nokia boxes were fed by a single channel each and had internal crossovers, so I just plugged those wires into the 6-1/2"s and let the speakers' internal crossovers do the work. What I'm looking to do now is take out the stock amp and power the speakers directly from my head unit - an Alpine 9803 or somesuch, I forget the exact number. I have found some places where I could get 3-way crossovers to wire in for the front speakers from the head unit output, but I'm puzzled as to where the stock crossovers are. I've seen this image (http://www.unofficialbmw.com/e36/ste...eo_pinouts.gif) but it doesn't match what I have in my '92. My amp is labled as a Blaupunkt and has two twelve-pin connectors hooked up to it, which sounds like this one (http://www.bmwworld.com/audio/wiring/e34_12pin.htm) but is different in that the rear outputs are done without seperation and only have one set of wires for each side.
Does anyone know which wires in this are which or are there any service manuals that would have schematics on it? Thanks.
007ben 07-15-2004 09:58 PM
there is a wireing diagram for the e36 around here. if you look around you can find it.
jllphan 07-16-2004 06:56 PM
1 Attachment(s)
Ya mean this one...
speedbump 07-16-2004 07:17 PM
Yeah, I'd seen that one, but it's not the same as what's in my car. My amp has two 12-pin connectors and no 26-pin one. However, I took out today and traced the wires and managed to figure them out - now I'm just waiting for my crossovers to get here and I'll bypass it completely.
007ben 07-16-2004 07:38 PM
thats the one. jllphan... do you just have a bunch of messages canned and ready to go? like that. and your odb1 conversion links?
Androulakis 07-17-2004 11:40 PM
Nope, that's not the right diagram for a '92. It uses the same amp the 91-92 E34's use, and its different from all the other ones:
Here is the right diagram.
http://www.parts4sale.com/bmw/E36/19...o/10spkr92.jpg
Take care,
George
Saggis 07-18-2004 04:24 AM
another easy way to find out speaker cables is to just take some small battery eg. 1.5v aa battery por anythingn and just touch it to a + cable and then just start trying the other cables withthe other end of the battry and you get a small noise in the speaker when u find one...
BMWAvatar 03-16-2014 12:39 AM
No diagram
Take care,
George
George, I don't see the diagram. Do you mind to post it again pls.
witeshark 03-16-2014 09:02 AM
Thread is from 2004
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
