E60 problem thread - Page 6 - BMW Forum - BimmerWerkz.com
post #76 of 83 (permalink) Old 02-22-2011, 11:35 AM
obama6493 is on a distinguished road
Originally Posted by Live_the_Curves View Post
Its BMW's fault for not testing the suppliers products. WTF
Ok... With todays standards... I'm almost positive that more than we even think or.. have talked about in the forum goes on to test the product line and producers of such parts that consist of a BMW. One thing that cant exactly be replicated.. due to time and its lact of practicality.. is longevity of a part... and or probability that it might fail. For example... BMW cant test 100 cars with the same parts.. to see how many out of those cars' parts will fail. Its not pratical.. so every now and then you might get a bad egg out of the batch. And if it is a vital part that is the part that fails.. a part will cause others parts to not work at or near their intended operation.
obama6493 is offline
post #77 of 83 (permalink) Old 06-15-2013, 12:01 AM
Steven Liu is on a distinguished road
Send a message via Skype™ to Steven Liu
Problems
Mine is a E60 Late 2007 520d with the tweaked engine.
Problems:
Fuel System Problems (BMW Admitted Flaw-Replaced)
OBC Issues (Replaced)
Bluetooth connect ability failure (Replaced, cost me nearly 2.5k US)
The bluetooth is a big problem, since i live in Taiwan, every part is exported therefore twice as expensive. The Bluetooth was alright and working before my 50k checkup, and when the car came back, which they resetted the computer, the bluetooth stopped working. This really sucks, because I have to pay for that.
I got really pissed off therefore the manager gave me a lifetime 30 percent off for all maintenance )
Steven Liu is offline
post #78 of 83 (permalink) Old 04-15-2015, 09:20 AM
aashu1 is on a distinguished road
Yes agree in your Active Drive System Failure.
Dealer replaced "valve block “reappeared and another valve block.
What is color of Exhaust Gas?
PREVENTATIVE VEHICLE MAINTENANCE
aashu1 is offline
post #79 of 83 (permalink) Old 11-11-2015, 07:21 AM
Manuchar87 is on a distinguished road
Send a message via Skype™ to Manuchar87
Hi,
I have 2004 525i E60. on my iDrive screen additionla information window which is in the left part of the screen disappeared and I cannnot swith it on.
When I go to Navigation the screen is totally black. All other fields, communication, climate and entertainment are working. Can anyone help with this?
Maybe someone hhad similar issue.
Manuchar87 is offline
post #80 of 83 (permalink) Old 04-16-2018, 08:23 AM
mdhira1 is on a distinguished road
thank you
mdhira1 is offline
post #81 of 83 (permalink) Old 04-21-2018, 04:19 PM
Dann-0h is on a distinguished road
Air mass control sensor
Dann-0h is offline
post #82 of 83 (permalink) Old 04-21-2018, 04:39 PM
Originally Posted by hmuchmo1 View Post
About issue #1 if you have aftermarket rims or had tires replaced recently have them balance checked, then see if you happen to need a centering ring.
Otherwise you could be experiencing shock/strut replacement, or the connector rod bushing being worn out.
Issue #2, can you define a while? seconds or minutes? I have had similar issues lasting only like 5-10 seconds while I am in DS mode.
Vibration: most likely you just need your wheels re-balanced. Very common symptoms and easy, inexpensive solution.
When you say “car stays revved up” are you talking just about rpms or also speed (does car not begin to decelerate)? That’s critical info to know before trying to begin to diagnose issue. Fact that fuel consumption gauge runs consistent with tach may be noteworthy. Assuming car does NOT continue to accelerate, likely a software issue. OBDII reader can scan for fault code(s) and guide tech to specific issue. Likely not a very costly problem.
Dann-0h is offline
post #83 of 83 (permalink) Old 04-21-2018, 04:47 PM
Originally Posted by skiman View Post
I have a 2008 535xi and the yellow engine light went on last night associated with a very rough engine idle. The dealership's closed due to the holiday weekend so I thought I'd throw this out to the community. Any thoughts? Thanks.
Most likely air mass control sensor needs replacement. Inexpensive.
Dann-0h is offline
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 1 04-01-2017 05:54 PM
Erratic Idle / Misfire / Cutting out makdolby 3-Series (E36) 12 02-05-2012 08:57 AM
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 02:16 PM
Alpine 9835 Fm Tuner Problem ultraviolet353 Audio and Electronics 7 09-23-2004 12:09 AM
