| what sound system is on your z3? if you have the HK setup, you have a 6'' subwoofer instead of the dual 3'' the non HK z's get, if you do have the 6'' sub, and dont ant to break the bank, you can get a Kicker CVT65, with is a 6.5'' subwoofer, you have to cut a bit of the box up inside, but its not visible anyways
if you want more bass, you can do what i am doing, sealing up the subwoofer enclosure with dynamat to make a "sub box" and having a custom lid made to hold the subwoofer, it will turn the whole enclosure into a sub box, look in the audio forum on here for pics
as for roadstermadness' setup, he actually has a BOX put in there because he is using the bigger kicker comp subwoofer
the difference between the comp and the cvt is that the cvt is a shallow mount, and doesnt require as much space as a normal sub but still (supposedly) bumps as hard
ill be having my sub put in either tomorrow or wednesday, ill post pics and let u guys know how it sounds
