z4 roof help - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 12-30-2009, 09:12 AM   #1 (permalink)
orr233 is on a distinguished road
z4 roof help
I have a 2003 z4 I'm having problems opening the roof. I have to manualy open the roof about 6" before the red light comes on. Then it opens almost all the way. It closes with no problems. After reading several threads I have an idea it might be the micro swith it the trunk. How can I test or jump that swith? I appreciate any help you can give-thanks!
orr233 is offline   Reply With Quote
Old 12-30-2009, 09:38 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
If the micro switch is in the wrong position, the roof will unlock but not retract.
To check this, manually lower the roof and and then attempt to raise the roof as normal. If it goes up, then the switch is bad.....
Old 12-30-2009, 10:12 AM   #3 (permalink)
microswitch
When I press the button with the roof closed there is no light at the switch. When I maually open the roof several inches the light comes on. After reengaging the red handle in the trunk the roof will open about 3/4 of the way. Then I have to manually open it the rest of the way. The roof closes with no problems. I have taken the switch out and re connected the lever on it. I have confirmed that the lever on the roof tray does slide down and triggers the lever on the microswith. From what I'm gathering from you is you believe the micro switch is bad. I've read in previuos threads that there is a way to put some jumpers in to temporarily bypass the swich. Do you know anything about this? I've also read some people disconnecting the battery then reconnecting it to reset it. What do you think about that idea? I appreciat your help. Thanks
Roof problems scott_wise 3-Series (E36) 1 08-06-2008 08:09 PM
HELP!!! Roof won't go up and it is about to rain!! thebhoy Z3 / Z4 /ZM 4 07-16-2008 10:31 AM
Roof Rack srgtyorkie 3-Series (E46, E90) 2 03-29-2007 01:31 PM
Roof Interior BeachBunny Wash & Detail 3 09-19-2004 02:30 PM
roof help Rich328 3-Series (E36) 1 09-06-2004 10:23 AM
