Welcome to the Werkz......
Have you checked the terminal connector to the cluster to make sure it's pushed all the way in & secure......also check to see if any of the connector terminals were not bent, when you reinserted the plug to the cluster.....
definitley sounds like a loose connection somewhere within the area you were working.......either in the cluster... but I don't know if you had that out.....but definitley in the steering column.
check all your connection points on every connector you unplugged
johnny
