water pump froze in housing 1.9 - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 10-22-2010, 09:18 AM   #1 (permalink)
Car: 1998 z3 1.9
havenh is on a distinguished road
I have tried to pull my water pump out according to the Bentley instructions but it was so froze that the edges broke off. I was doing it slow. Have tried everything-rubber mallet, twist, etc. Afraid to try heat. any ideas.
Thanks
havenh is offline   Reply With Quote
Old 10-22-2010, 03:20 PM   #2 (permalink)
Car: 1998 z3 1.9
water pump stuck z3 1.9
After over three weeks of pulling, cutting, pounding, and grinding I got my pump loose. The Bentley book said you were simply supposed to turn two bolts and it would slide out. But that doesn't work if you have a lot of corrosion in the housing. It was stuck in so hard that even with 3 weeks of PB blaster it wouldn't budge. It only moved after I had destroyed half the pump shell(which was pretty well corroded anyhow) I should have pulled it at 60,000 instead of 100,000 miles.
Anyway hopefully just got the easy work now. Belts, thermostat, flush, and install new water pump.
water pump froze in housing 1.9-imag0235.jpg   water pump froze in housing 1.9-imag0242.jpg   water pump froze in housing 1.9-imag0230.jpg
Old 10-22-2010, 03:34 PM   #3 (permalink)
Nice of you to share this, thanks! In the future other members are bound to appreciate it!
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
water pump again bimmer3214 3-Series (E36) 9 01-26-2006 09:03 PM
Water Pump '93 93 325i 3-Series (E36) 5 09-22-2004 01:23 PM
Leaky Water pump or the Themostat Housing RedBeemer95 3-Series (E36) 12 08-21-2004 07:13 PM
