Strong Strut - strut braces - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 09-23-2008, 01:45 PM   #1 (permalink)
Car: 2006 Z4 M Coupe
z4mcoupe is on a distinguished road
Before doing this I was very skeptical as to whether or not you can feel a difference with the strut brace on the Z4 M. I would have to say that you can most definitely feel the difference.
This item cost me $395. It was easy to install, although it will require a wheel alignment because you are unscrewing the strut bolts. i recommend you get the textured finish, as this couldn't match better if they tried with the plenum, airbox and valve cover.
I suggest that if you do this that you also knock out the strut pins and get some free negative camber prior to getting the alignment. Trust me, its cheaper that deciding to do it later and having to get a second alignment......at $85.....
z4mcoupe is offline   Reply With Quote
93' m5 strut braces.... BANKROBBER M-Series (M1, M3, M5, M6) 1 04-19-2006 03:42 PM
Strut Tower Braces kyle_baker 3-Series (E36) 14 07-08-2005 04:57 PM
Strut Braces Info Needed RedlinedRU 3-Series (E36) 5 12-31-2004 12:03 PM
B&B exhaust, Strong Strut & Butt Strut-M Roadster ggreenwood Classifieds Sell & Buy 3 05-22-2004 04:00 PM
fitting strut braces or strut bars ultraman90 3-Series (E46, E90) 6 11-25-2003 02:18 AM
