No sound from radio - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 06-11-2011, 03:12 PM   #1 (permalink)
cdubvr6's Avatar
Car: 2005 BMW Z4 2.5i
cdubvr6 is on a distinguished road
No sound from radio
Hello all, I'm a new ower of a 2005 BMW Z4 2.5i and I'm having a problem with the radio. The radio turns on and all of the functions work but I can't get any sound out of it. I checked fuse #'s 47, 48, 49, and 50 and all were fine. Then I remembered that it has a amp so I went to check the fuse for that but can't find where it would be. I looked on the amp and next to it but could not find a fuse for it.
So my questions are,
1) Is there a fuse for the amp?
1A) If so where do I find it?
2) Am I on the right track to finding out what is wrong?
2A) If not where should I be looking?
On a side not I did a search for this here and all over the web with very little info found.
Thank you for any info,
Corey
cdubvr6 is offline   Reply With Quote
Old 06-11-2011, 06:54 PM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz.
If you the radio is on and you go for a drive 10 - 15 minutes should be enough, can you feel if the amp is warmed up at all? If not then you are probably on the right track. Are you able to easily locate the 12 volt supply to the amp and check if it actually has power? If there isn't any power, you'll probably find the supply fuse is in a similar location to that of the stereo.
Did the unit stop working at the same time as any other event, eg routine service etc?
Riding in style
Old 06-11-2011, 07:05 PM   #3 (permalink)
cdubvr6's Avatar
It just stoped working so I figured it had to be a fuse but every fuse in the car that I have found is fine. I will have to check to see if it gets warm or not. I will also check to see if it is getting power. Thanks for the tip.
Old 06-11-2011, 07:19 PM   #4 (permalink)
brettski's Avatar
Do you have access to a multimeter or test light?
Riding in style
Old 06-11-2011, 07:34 PM   #5 (permalink)
cdubvr6's Avatar
Yes I do but I'm 900 miles away from the car so I will do some testing on it when I get back to Texas.
Old 06-11-2011, 08:29 PM   #6 (permalink)
brettski's Avatar
No wonder you can't here the radio. I am surprised that you can tell whether its on at all
Riding in style
Static sound when playing radio bimmerr 3-Series (E36) 0 03-30-2011 07:31 AM
95 740i Radio sound problems tberardi 1,6,7,8 - Series and Mini Cooper 3 02-18-2009 07:51 PM
Kenwood HU only make sound in radio mode? (E39 stock amp) jinroh Audio and Electronics 11 06-26-2008 10:47 PM
Radio Works But No Sound. Amp Problem? Help!! Miket Audio and Electronics 2 05-10-2005 07:19 PM
