New Z3 Owner... got a couple questions. - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 03-18-2009, 08:44 PM   #1 (permalink)
z261994 is on a distinguished road
Got the new car a couple weeks ago, and I love it
It's a Violet 97 with tan interior and top. Completely stock.
I know it's due for an oil change soon and the light is going to come on. I also know there's a way to clear the light with jumping a couple pins in that round connector under the hood. Does anyone have the info on this?
I also know I need a certain wrench to change the oil filer. It's the 1.9L. Anyone know the size offhand so I can pick it up?
..and as long as I'm at it, what the oil capacity is?
The stock stereo is a component setup with the tweeters in the doors and mids in the kick panel area. Does anyone know if this uses a factory crossover, or is it all run through the stock radio? I'm also wondering if the factory sub is amped, or is it through the radio?
It has the usual sagging glove box... what does everyone normally do to fix it?
And I can't figure out the clock and temperature display for the life of me! Sometimes it shows the temp when I start the car and sometimes it shows the clock. When it shows the temp, I can press the clock button and it switches over, but nothing changes it back to show temperature!? The button labeled "S/R" doesn't seem to do anything at all. The only way it goes back to temp is to just wait a few starting cycles until it decides to go back.
It seems like a front wheel bearing may be on the way out... is this a common problem?
5th gear seems a little too tight to shift into. Are there replaceable bushings that could help?
Help me out and I'll post pictures
Thanks, Kyle
z261994 is offline   Reply With Quote
Old 05-14-2009, 07:16 PM   #2 (permalink)
LRod is on a distinguished road
Congratulations on your new purchase. I can't answer your other questions, but I can tell you that I needed to replace my driver's side front bearing at 55,000 miles, which I didn't expect. Then, like you, my ears told me how the stock stereo really wasn't suburb, so I replaced that. Then, I purchased a Z3 windscreen (windblocker). Those two purchases made the car, at least for me.
Let us know how that front bearing works for you.
LRod is offline   Reply With Quote
New Owner have a couple (a lot) of questions lovenlife 3-Series (E46, E90) 1 07-30-2008 09:59 AM
Couple Questions alexlikh87 3-Series (E36) 13 05-10-2005 11:49 PM
Just A Couple Questions BMWspeedracer Audio and Electronics 7 04-01-2005 11:10 AM
Fresh E39 %40 Owner, Couple Of Questions. HardStep 5-Series (E12,E28, E34, E39, E60) 1 11-15-2004 06:00 PM
Couple Of Questions, Please Help TurnerBimmer 3-Series (E21, E30) 2 10-20-2004 11:13 AM
