Interior light and key chime - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 11-03-2012, 05:48 PM   #1 (permalink)
Car: 1999 BMW Z3
senikc is on a distinguished road
I have a 1999 Z3 when I close the drivers door, the inside light stays on, and the key chime goes off as if the door was open, I have not been able to find the door switch, does anyone know where it is located and what the problem might be with it?
Thanks
Charles
senikc is offline   Reply With Quote
Old 12-24-2012, 02:31 PM   #2 (permalink)
Zedfor's Avatar
Car: 2003 BMW Z4 3.0si, 2007 BMW X3 3.0
Zedfor is on a distinguished road
Thanks
Charles
The switch is integrated in the door latch. Stick a screwdriver in there to push the switch. The switch is a little snap-button in the part of the latching mechanism thats mounted to the body of the car. You can leave the door open, push the button with your finger or screwdriver and wait for the courtesy light circuit to time out. If the problem persists, make sure it's the driver's door jamb switch by re-doing this little experiment on the passenger side.
If you don't know where you are going, any road will get you there.
Editor - ZSCCA's CruiZin' NewZ
ZSCCA
Zedfor is offline   Reply With Quote
Old 12-24-2012, 07:16 PM   #3 (permalink)
Car: 1999 BMW Z3
Thanks for the information, I had discovered the location of the switch, from that point the problem was evident, there is a piece of hard plastic which goes around the body mounted switch/striker, on the inside where the latch has rubbed over the years it had become degraded and did not hold the door and latch mechanism in far enough to depress the switch. I rotated the plastic part and put some adhesive on the damaged part, and held it back together, now that I have roatated the plastic bushing the problem is solved.
Thanks again for your help.
Some Of My Interior Light Have Gon Out Help Please!! markieboy 3-Series (E36) 1 09-24-2008 08:07 PM
E30 Door Chime bimsupreme 3-Series (E21, E30) 14 10-30-2006 04:17 PM
Need some experts to chime in... FrankieMyOne 3-Series (E46, E90) 3 01-15-2006 12:41 PM
No chime? I'm disappointed Morpheous 3-Series (E46, E90) 3 11-19-2005 11:21 PM
Headlights left on, no chime or anything gthoman 3-Series (E46, E90) 2 09-12-2004 08:32 AM
