How can I change odometer back to Miles from Kilometers? - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 10-11-2008, 02:45 PM   #1 (permalink)
darreldore's Avatar
darreldore is on a distinguished road
I own a 2000 BMW Z3 2.8 (VIN # LF42374) with 44,000 miles on it. I drove my car , which had ½ tank of gas for 20 minutes, parked it for 25 minutes and when I started it the following occurred:
A - The fuel gauge needle falls to empty, but the low fuel light does not come on.
B – The water temperature gauge needle falls to cold and the red overheat light comes on.
C – The Brake Pad warning light comes on.
I immediately stopped at a gas station, filled the tank and checked the cooling system for leaks or signs of overheating. I found nothing wrong.
When I restarted the car, everything returned to normal, except the odometer switched from reading in miles to reading in kilometers.
Do you have a clue as to what could cause such wacky behavior and how I could get my odometer to read miles again instead of kilometers?
darreldore is offline   Reply With Quote
Old 10-12-2008, 04:39 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
You really need to get a diagnostics done, also could be the battery not pushing out enough power.
Old 10-12-2008, 09:05 PM   #3 (permalink)
bimmerted is on a distinguished road
sounds electrical -hence, start with simple things like fuses, battery posts, connections of or pertaining to components you mentioned. Clean and reconnect - you've nothing to lose.
Wacky gas guage is common. It happened to me upon fillling my tank to max. I was informed that it causes the sending unit to act eratically. When level came down, everything was back to normal. It may sound strange, but use good fuel, ocassionally add dry gas; and a 12 oz bottle of Techron to a full tank. It helps remove tarnish/deposits on sending unit stuff. Also helps clean fuel injectors and other fuel related parts.
When you disconnect battery cables @ posts (for cleaning) do negative first. Also reset neg last.
This will require your radio code to be entered (using radio buttons). My code/5 digit # was inside my owner's manual paperwork (simple). Find radio code before cleaning post to make sure you have a radio when all is done. Note, your computer will reset when you disconnect battery ground. This may help other wacky components,
This is basic advice - not technical. Good luck.
PS: Diagnostics are free at Auto Zone -takes 3 minutes once they plug in OBD. A
good BMW Z3 manual is very helpful if you want to enjoy your car (not Chiltons).
bimmerted is offline   Reply With Quote
How do you change from Kilometers to Miles on a old BMW? boby619 5-Series (E12,E28, E34, E39, E60) 3 10-09-2008 12:10 PM
change odometer from milles to KM feras72 5-Series (E12,E28, E34, E39, E60) 1 07-18-2008 09:16 AM
Change Odometer from KM back to Miles? stoeger 3-Series (E36) 5 03-30-2006 09:57 AM
Switching Miles/kilometers On Display HardStep 5-Series (E12,E28, E34, E39, E60) 7 01-24-2005 03:24 AM
My Odometer Is In Km, And I Want Miles! Phatrician 3-Series (E46, E90) 3 12-18-2004 10:16 AM
