| This is a common problem in all BMW's, you will need a window regualtor. Replacing the regualtor isn't anything crazy but getting the correct window adjustments can be tricky after, if you don't feel confident in doing it bring it to the dealer because if you don't get those adjustments just right you will have water leaks, wind noises, etc which in the long run will cost you much more. Hope this helps |
