Heating Issue - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 01-28-2013, 07:37 PM   #1 (permalink)
sutpheme is on a distinguished road
Heating Issue
I have a 1999 M Roadster. Recently, I noticed that when my car is at idle, the blower will not put out hot air. I noticed this when I was stopped for a railroad crossing. It was putting out hot air before I stopped, then over about a minute it cooled off to outside air temperature. A few seconds after I started moving again, it blew hot air.
This does not happen with the air conditioning. Any ideas what might be acting up?
sutpheme is offline   Reply With Quote
Old 01-28-2013, 08:01 PM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Its possible your fan clutch has gone. I noticed this once in my E36. The fan clutch controls the main engine fan. If it is not working, when the car is moving air is pushed against it making it seem like it is working. When stopped the fan has no air to move it, and may continue spinning freely. One way to tell if you fan clutch has gone is take a rolled up newspaper and insert it into the fan while the engine is running. If the fan stops then the fan clutch is bad and needs replacement.
Click HERE to see my E36 Blog
Old 01-30-2013, 05:59 AM   #3 (permalink)
I checked the fan clutch, and it is still good. Any other ideas?
Old 02-01-2013, 02:36 PM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Have you replaced any components of the heating/cooling system or added coolant recently? You could have air in your coolant system. Do you know how to bleed the coolant? Give that a try.
325i heating up, removed t-stat still heating up.. Please read!! azmattaz06 3-Series (E36) 3 02-07-2011 01:04 PM
Strange Over Heating Issue Jonnyblaze1130 3-Series (E46, E90) 2 06-11-2009 12:07 AM
Roof issue red light flashing! (and Sat Nav issue too!) doopranal Z3 / Z4 /ZM 0 03-24-2009 06:25 AM
Car Heating Up Again- Help alext 3-Series (E36) 7 11-01-2004 07:18 PM
Car Heating Up - Please Help alext 3-Series (E36) 4 10-06-2004 01:02 PM
