Difficulties selecting gear from standstill - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Z3 / Z4 /ZM
Z3 / Z4 /ZM BMW Z3 Forum & BMW Z4 Forum - Covers all the past and present Z3/Z4 vehicles including: BMW Z4 Coupe 3.0si, BMW Z4 Roadster 3.0i, Z4 Roadster 3.0si, and the ZM Coupe and Roadster (BMW Z4 Forum, BMW Z3 Forum, BMW ZM Forum)
Old 03-23-2010, 08:17 AM   #1 (permalink)
Car: 1997 BMW Z3 M 3,2
F1Wannab is on a distinguished road
Hi. Just bought a very nice 1997 Z3 M Roadster with only 66.000 KM on the dial. Car in perfect condition. From standstill however selectin 1. gear can be very "heavy". No sounds or problems from the gearbox what so ever when driving, only when selecting. How "heavy" is the movement supposed to feel? There is no problem with the sync. mechanism. Any ideas/comments? Does anyone have experience with a "short shift" mechanism for this car? Thanx.
F1Wannab is offline   Reply With Quote
Old 03-23-2010, 08:43 AM   #2 (permalink)
Mr. Clean
BimmerE39's Avatar
It's actually pretty normal on BMW's for there to be some resistance when going into first gear from neutral. This can be particularly true on some of the models which have a shorter throw as a short shifter tends to add notchiness to the shifter feel.
Old 03-23-2010, 12:49 PM   #3 (permalink)
Car: 1998/BMW/Z3 2.8L
tpz3 is on a distinguished road
I have a 1998 Z3, 45,000 miles, same kind of issue when putting car in reverse. I have to use 2 hands. Is this normal as well? Like F1Wannab no unusual sounds, scraping from gear box or clutch
tpz3 is offline   Reply With Quote
Old 03-23-2010, 02:19 PM   #4 (permalink)
Mr. Clean
BimmerE39's Avatar
No, the synchros are really notchy so I don't think it's unusual. You can loosen them up by putting the transmission in neutral and shake move the shifter from left to right in neutral. This loosens everything up and it should go into gear easily.
Old 03-24-2010, 12:46 AM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
trapped air in clutch lines?
Old 03-24-2010, 05:39 AM   #6 (permalink)
Found this: http://www.zvolution.com/documents/2...d_to_Shift.pdf
and loads of other good stuff ....
Old 03-24-2010, 10:01 AM   #7 (permalink)
Thumbs up
Thanks for the info. I'll give it a try and see how it goes. the bulletin was interesting...I wonder how hard this would be to do yourself...
Old 03-25-2010, 03:06 AM   #8 (permalink)
Removing the gearbox is not DIY I guess
525 tds stalling when selecting drive from park atouchoffunk 5-Series (E12,E28, E34, E39, E60) 1 02-08-2010 01:04 PM
Shaking at Standstill Driver530 5-Series (E12,E28, E34, E39, E60) 4 08-21-2007 02:05 PM
Guage cluster swapping, difficulties. Cue Starmavin... daklunk 3-Series (E21, E30) 2 04-20-2007 09:20 PM
1988 530i Starting Difficulties Harramog 5-Series (E12,E28, E34, E39, E60) 9 10-30-2004 06:40 AM
