| wind noise Thanks, for the idea. I will try that once I get car out of winter storage.
I noticed after washing the car that there is water/moisture at the posterior/back end of the window just above the top inside of the door. WOULD this indicate a bad seal or a misaligned window?????
I only have 4K miles on the car so it is still covered under warranty. However, when I called dealer and told him a about the problem, I got the usual run around-there's not a whole lot we can do about it???????
Thanks again,
Bimmer0304 |
