X3 E83 dcs light on - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > X Series
X Series BMW X3 Forum - Covers all the past and present X vehicles including: X3, X5, X6
Old 06-04-2008, 06:14 AM   #1 (permalink)
jcampos is on a distinguished road
X3 E83 dcs light on
fuse 40 in glove box blown then the 4x4 light on
jcampos is offline   Reply With Quote
Old 06-05-2008, 10:19 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Question
replace fuse... and let us know? :-)
Old 06-05-2008, 10:52 PM   #3 (permalink)
f 40 blow off
i did and after about 5-10 min. blow again. I replace the sensor, delete the
code and fail again.
Old 06-05-2008, 11:04 PM   #4 (permalink)
Well then there's a short causing that fuse to overload. Gotta find and fix that issue.
Old 06-05-2008, 11:15 PM   #5 (permalink)
Thumbs up
touche'
Old 06-05-2008, 11:16 PM   #6 (permalink)
Arrow
ok. seriously. what is the designation of fuse 40? the fuse panel or ur owner's manual will tell u.
I'll need the yr model and engine displacement of your X3 for reference
Old 06-06-2008, 07:02 PM   #7 (permalink)
F 40
I fix the problem ,this fuse suply voltage to steering angle sensor and shifter
light .i found a short to ground cable in the shifter conector,is the red/black
cable ,fixed ,reset and thats it. thanks .
Problem: DCS and ABS lights on :( thejobman 5-Series (E12,E28, E34, E39, E60) 5 12-18-2008 04:25 AM
ABS light, brake light and TCS offline on 528i... ideas? rmory 5-Series (E12,E28, E34, E39, E60) 5 08-14-2008 10:01 AM
Brake Light Circuit And Tail Light Failure 325is1994 3-Series (E36) 7 08-05-2008 12:00 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
'94 318is: brake light & fog light question ultraviolet353 3-Series (E36) 2 08-14-2004 01:46 AM
