Tire Pressure Monitoring Light on 2006 X5
5K views 1 reply 2 participants last post by  darkhorse737
#1 ·
Warning light comes on. Tire pressure is consistent. No leaks. Reset the system following the owners manual instructions. A few days later the damn light is back on. Previous owner had same problem the last 6 months he had it. What should the dealer do - the car is still under warranty. Any thoughts would be greatly appreciated.
#2 ·
let the dealer worry. that should be the least of your probs since as you say it is still under warranty.
could be anything from a slow tire leak from 1 or more tires; defective wheel sensor in one or more tires. defective antenna... or the brain itself is screwed. Or ... it might even be a recall item ;-)
