Service indicator lights reset on an X5 (diesel) - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > X Series
X Series BMW X3 Forum - Covers all the past and present X vehicles including: X3, X5, X6
Old 08-03-2006, 11:45 AM   #1 (permalink)
solanog is an unknown quantity at this point
Hi, my dad has a 2002 X5 (3.0 diesel), does someone knows how to reset the SIL? I can't even find the connector on the engine bay. On other BMWs, five and three series it is visible but I don't see it on the X5, is it in other place or does it has a different system?
solanog is offline   Reply With Quote
Old 08-10-2006, 04:14 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Vehicles outside of the 2000 year mark DO NOT have a 20 pin connector under the hood, the SIA reset is done via the instrument cluster or the BMW GT1 machine. try this, press and hold the left button (I may be wrong and it might be the right button) on the instrument cluster, turn key on while holding this button hold until the Service Indicator flashes release button and press again this will reset the SIL. Good luck.
Come see me at MySpace
Old 08-10-2006, 04:18 PM   #3 (permalink)
Thanks, I will give it a try. I think this car has only the reset odometer button. I will give this a try and let you know if I need more help. Maybe I could bring a picture of the dashboard and post it.
Old 08-14-2006, 11:17 AM   #4 (permalink)
Thanks I reseted the lights, all the greens are on.
I had to push a couple of times after reset flashed.
Thanks for your help.
BTW, can the inspection and other warnings be reseted independently or only a complete reset can be done, as the one I did?
Old 08-14-2006, 06:42 PM   #5 (permalink)
325isBaby's Avatar
Car: 2005 330xi
the inspection light is reset the same way as the oil service indicatior, but other lights (like check engine and so forth) have to be reset with a scan tool
Old 07-18-2008, 12:48 AM   #6 (permalink)
aminf is on a distinguished road
dear,
i had the same problem with my 2002, X5 4.4 petrol, but this solution didnt work on my car. I am still not able to reset the SIL. any alternatives?
thanks
aminf is offline   Reply With Quote
Old 07-18-2008, 09:47 AM   #7 (permalink)
I was lucky to reset the SIL lights. I don't have the exact procedure I followed, but it was something like press the button (In my case the trip odometer reset button), turn the ignition while keeping the button pressed. Wait until the display shows reset it will show some messages.
The dash on this car is the most simple one, it doesn't show alphanumeric info, just the odometer, ext temp, kms able to travel with the actual fuel, etc.
Old 07-20-2008, 12:12 PM   #8 (permalink)
Smile
thanks a lot for your valuable comments. i shall try it again.
Old 10-10-2008, 06:24 PM   #9 (permalink)
Did it work?
Old 01-16-2009, 03:51 PM   #10 (permalink)
abhik382 is on a distinguished road
Anybody can tell me about the BMW tail lights?
abhik382 is offline   Reply With Quote
Reset Oil Service - Help ?! gs023 3-Series (E46, E90) 1 06-21-2005 02:11 PM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
