Replacing Air Mass Boot Sensor in X5...HELP - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > X Series
X Series BMW X3 Forum - Covers all the past and present X vehicles including: X3, X5, X6
Old 08-03-2007, 10:08 PM   #1 (permalink)
youngbloodz is on a distinguished road
Angry Replacing Air Mass Boot Sensor in X5...HELP
Ok guys, recently my air mass boot sensor cracked in my X5, and i have a problem, there is something in the way of replacing it:
What is that box, and how would i go about removing it?
Also the boot looks like this:
Where that quarter is, that is what happened to mine. Is there ANY way or ANYthing i can put to seal it up to drive it to work tomorrow, I will be replacing the boot after work once I find out how to remove that thing, but I have no other way of transportation to work tomorrow, and the boot being cracked is the problem. I need a temporary solution to patch that up so please help me! Thanks
youngbloodz is offline   Reply With Quote
Old 05-15-2008, 04:19 PM   #2 (permalink)
Hootie is on a distinguished road
Wow, dead forum around here. Anyways, for anyone who finds this thread in the future... that little black box can be removed with a socket wrench, no harm done as long as you put it back in place. I had to remove the lower air duct on my '00 328i (same layout) with a razer blade, then removed the hose clamp, then installed the new duct with new hose clamps. It's really quite a simple job.
Hootie is offline   Reply With Quote
Old 02-22-2009, 01:44 PM   #3 (permalink)
shadow boxer is on a distinguished road
okay i just did mine. the box you speak of is eally not in the way. the boot is a bitch to replace. especially the small hose that goes to your icv. i'm interestd to know if that solves all your issues. replacing mine helped but i still have a rough idle issue. a 6mm box wrench was the only thing i was able to fit in the space to tighten the clamp. good luck
shadow boxer is offline   Reply With Quote
Wanted: Air Mass Meter Boot topless_328 Looking For 1 05-06-2008 01:36 PM
mass air flow sensor peri 3-Series (E36) 2 02-15-2006 08:01 AM
e39 540i Air Mass Sensor HardStep 5-Series (E12,E28, E34, E39, E60) 1 10-17-2005 10:15 PM
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Replacing Air Mass Sensor johnpjohns 5-Series (E12,E28, E34, E39, E60) 1 02-10-2005 04:15 PM
