Need help: '03 X5 transmission fluid capacity - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > X Series
X Series BMW X3 Forum - Covers all the past and present X vehicles including: X3, X5, X6
Old 03-16-2009, 08:39 PM   #1 (permalink)
BShow is on a distinguished road
I have a '03 X5 3.0i. I need to know the how much fluid is replaced with a simple drain and re-fill of the transmission.
I drained the fluid and forgot to capture it in a separate pan so that I could measure how much came out. Doh! I've found several sets of instructions that indicate you fill it up to the fill hole, then start the engine and engage each gear, then top up from the fill hole as necessary.
Well I tried that and when I opened the fill hole with the engine running trans fluid came shooting out everywhere!
I don't think I've put enough back in, but according to the procedures I've found I've put too much in. I put about 2 qts back in before I started it, it seemed like a lot more than that came out.
The tag on the side of the trans indicates it is a GM part No. 96024222, anyone know what trans that is? A google search turns up nothing.
If anyone can help me get the right amount of fluid back in my trans I would be grateful.
BShow is offline   Reply With Quote
Old 03-16-2009, 10:28 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
You know the transmission has to be at a certain tempature to hot and you wont get enough in to low and you'll over fill it
1992 318i Coupe parts car
I am Captain Obvious
Old 03-18-2009, 03:48 PM   #3 (permalink)
Just to close out this thread, it turns out I was using the wrong fill hole.
The fill is on the rear drivers side, 17mm socket to remove. Once I used the right hole, the procedure worked as advertised.
Transmission fluid Allan Funez 3-Series (E36) 6 02-13-2009 07:17 PM
transmission fluid kdmf317 5-Series (E12,E28, E34, E39, E60) 4 07-21-2008 04:13 PM
transmission fluid trinidad 325i 3-Series (E36) 1 03-16-2007 06:06 PM
Automatic Transmission Fluid / Steering Fluid akbarz 3-Series (E46, E90) 1 08-23-2004 02:04 AM
Transmission Fluid Kevin325i 3-Series (E36) 8 05-20-2004 09:48 PM
