Hi- My 2001 X5 4.4 coolant reservoir tank is leaking where the top and bottom of the tank join. Is it suggested to buy a new tank (and can I do that myself) or can I just seal the leak w/ a type of epoxy or sealant? I appreciate anyone's help... PH
if you prep your surface well, it might work. no harm in trying. jst make sure u use the 24 hr cure epoxy compunds. 5 min epoxy will not work.
What u are up against is that the reservoir pressures can reach as much a 16psi or higher... whether epoxy can hold that pressure, i really cannot say.
Just wanted to comment on this although I don't think my problem was the same thing the problem i did have seems to be pretty common. My washer fluid was leaking out due to one of the pumps going bad (though the pumped still worked it was leaking). Here's a little write up I did on the parts I got and how I fixed it for cheap:
It's good that did it by yourself. But every time you can’t do it, somewhere and somehow you will need a BMW repair shop to get it repaired. But be very careful when you repair your by yourself, by mistake you can do harm to your car as well for yourself.
