Charging System - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > X Series
X Series BMW X3 Forum - Covers all the past and present X vehicles including: X3, X5, X6
Old 05-25-2008, 09:46 PM   #1 (permalink)
mkalinak is on a distinguished road
Exclamation Charging System
I have an '03 X5 4.4i and the battery/charging warning light has been going on and off. Looks like I may need and alt. Any idea on how much this service should run me? Any recommended service centers/mech's in central nj?
mkalinak is offline   Reply With Quote
Old 05-26-2008, 02:11 AM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
How many miles? Is it the OEM Battery? They normally last like 5 years....
I'm in cali so i cant help you with the repair shop thing... just find a local Independent Shop!
1992 318i Coupe parts car
I am Captain Obvious
Old 05-26-2008, 10:53 PM   #3 (permalink)
I have 77k miles. A new battery was put in two weeks ago, after the system was tested and determined that the alt was pumping out the right voltage. When I took it in, the charging light was intermitent (seven days apart) quick on/off.
Yesterday, the light was blinking once every minute for 15 mins. I shut it down and towed it to my hometown BMW dealer. I believe the estimate will be around $1,400.
I don't understand since the alt costs ~$450 with shipping from Bavauto.com and should be under 3 hours in labor.
What do you think/recommend?
Old 05-26-2008, 11:50 PM   #4 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
labor to change alternator is 1.8 -2.0 hours accdg to ALLDATA and Mitchell standards... it should be even less if your X5 is still under warranty. you do the math ;-)
Old 05-30-2008, 06:47 AM   #5 (permalink)
pepsicola is on a distinguished road
I don't know about US, but 03 X5 4.4 came in 2 different engine.
M62 or N62(later one). By just looking at it, the N62 engine has relatively newer engine cover with 2 lumps, one on each bank of the engine.
Later one is easier to change, it's just a ordinary alternater.
However, the older one, being a water cooled alternater, it's a bit harder. And require a coolant top up and bleeding of the coolant system.
But, seeing how cheap you got quoted for the alternater, I believe it's the later one you've got. Coz the the older one is like 2k part alone.
pepsicola is offline   Reply With Quote
charging system (bad alt) BALKAN 5-Series (E12,E28, E34, E39, E60) 1 04-08-2007 07:56 PM
Charging System Light CiscoKid 3-Series (E36) 5 05-26-2006 12:37 PM
Charging Problem Help Breaker2944 3-Series (E36) 6 02-10-2006 11:12 PM
Bmw Charging System bmwfam123 3-Series (E36) 2 05-27-2005 04:13 PM
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
