» Site Navigation »
» Related Sites
» Buyers Guide
» Network Links
08-04-2004, 03:57 PM
#1 (permalink )
Hi,
Is anyone know how to get rid of the waterspots on paint and window?
Thanks
Ming
08-12-2004, 05:06 PM
#2 (permalink )
Try an "acid bath." Mix water and vinegar together, it should do the trick. Make sure to polish and wax the paint when you are done to protect the paint, the vinegar will strip the wax.
08-12-2004, 06:35 PM
#3 (permalink )
If they're not too bad you can use some quick detailer.
08-12-2004, 10:06 PM
#4 (permalink )
Car: 00 Prelude, 95 525i, 85 635CSi
as was mentioned before, acid bath, paint cleaner, then claybar
Redo all your wax then.
__________________ <iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
08-13-2004, 02:22 AM
#5 (permalink )
my neighbor used rubbing compound on his water spots.
08-13-2004, 02:31 PM
#6 (permalink )
Originally posted by white 330ci @Aug 13 2004, 04:02 AM my neighbor used rubbing compound on his water spots.
NO! NO NO NO NO NO!
Rubbing compounds are FAAAAAAAAR too agressive for clearcoat paints.
08-13-2004, 03:41 PM
#7 (permalink )
Take 15 Mol Hydrochloric Acid...also called HCl. Pour it on and use gritty sand paper or steel wool to rub it in. Spray with water and dry.
__________________ <a href='http://www.RetroSpek.com' target='_blank'>RetroSpek Website - Retro Vintage Everything</a>
08-14-2004, 12:51 AM
#8 (permalink )
Duragloss makes an AWESOME glass waterspot remover.
It's on this page
https://www.duragloss.com/new/products/gl-cleaners.htm
It's called "Nu-Glass". you might be able to find it in some retail stores if you live in the mid-atlantic states, VA, NC, SC, but you can order it from them. I love that stuff. Made my windshield look like new.
DO NOT USE ON PAINT!!! lol
08-14-2004, 03:54 AM
#9 (permalink )
Try Gel-gloss from Home Depot. It will take water spots off, light scratches from paint and leave your glass silky smooth.
__________________ 2004 E60 530is, Delivered 12/12/03, TiSilver/LGrey, PP, SP,PS, PDC, ACC, FRS, Step, Xenons, clear bra, body colored rear inserts. (Retired, 1983 henna red 320is)
08-15-2004, 01:43 AM
#10 (permalink )
ex owner/admin
whatever steps you take to remove your spots, please do understand what you are doing. a mistake could cost you more
09-10-2004, 11:03 PM
#11 (permalink )
try drying with some newspaper.
09-17-2004, 07:23 PM
#12 (permalink )
I may be misunderstanding your water-spot problem. Is it water-spots from washing the car and letting it air dry? Or is it something that has become more permanent?
__________________ <img src='http://home.comcast.net/~farrieta/index_files/image001.jpg' border='0' alt='user posted image' />
<a href='http://www.328i.org/index.php' target='_blank'>328 life</a>
1998 328
09-18-2004, 12:54 PM
#13 (permalink )
hard water spots are caused from water "staining" your car... example of a cause would be letting your car sit in the sprinklers
__________________ <img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
Sponsored Links Advertisement
Thread Tools Display Modes Linear Mode
