Warning Sticker Removal - BMW Forum - BimmerWerkz.com
Old 08-31-2004, 11:08 AM   #1 (permalink)
jonesfish325i is an unknown quantity at this point
Hello All, just bought a 04 325i and I was wodering the best way to remove the airbag Warning sticker on the passenger side dash. I tried pulling it off slowly, but it is leaving sticky residue on the trim. Is it safe to use a product like Goo Gone to remove the residue, or do you recommend something else? Thanks.
jonesfish325i is offline   Reply With Quote
Old 08-31-2004, 05:58 PM   #2 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
Slvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond repute
Send a message via AIM to Slvr e39
I would say rip it off and use goo gone or goof off ( i recommend goof off because I have used it for things like that before)
So I would say rip off the sticker slowly, relatively carefully, then use the adhesive remover...*WARNING* when you use the adhesive remover have a sponge handy, and whipe it off clean right when you are done getting the sticky stuff off...if you do that reletively soon it will not damage anything.
Plus, I dont mean to scare you with that warning, because I use this stuff all the time and never had a problem. But I told you just so you dont leave any traces of it on there for a long periof of time
WELCOME TO THE FORUMS!! STICK AROUND!!!
Dinan Stg 2 Phoenix Yellow M3
Slvr e39 is offline   Reply With Quote
Old 08-31-2004, 10:59 PM   #3 (permalink)
/Banned
HamannM3's Avatar
HamannM3 is an unknown quantity at this point
In the 2001 325i i cannot make out if the airbag sticker is painted on the visors or a sticker. either way how should i go about removing that?!
HamannM3 is offline   Reply With Quote
Old 09-01-2004, 12:05 AM   #4 (permalink)
KillFox is an unknown quantity at this point
Send a message via AIM to KillFox Send a message via Yahoo to KillFox
I dont know if this works on the 01's, as I havent tried it on my car. However, either here or E46fanatics.com reccommend that you take your visors out of your car, and use a iron on a lower setting carefully, and remove the stickers slowly. The result should be the stickers and the goo come off together
<img src='http://3dwire.net/~matt/killfoxsig2.gif' border='0' alt='user posted image' />
KillFox is offline   Reply With Quote
airbag warning removal exjarhead328 3-Series (E46, E90) 0 03-23-2004 12:02 PM
Brake Lining warning Light Jefbrunton 5-Series (E12,E28, E34, E39, E60) 5 01-07-2004 04:07 PM
Brake Lining warning Light Jefbrunton 5-Series (E12,E28, E34, E39, E60) 1 11-29-2003 07:25 AM
