Two Days After A 2 Coat Polishing... - BMW Forum - BimmerWerkz.com
Old 10-03-2004, 05:15 PM   #1 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
As it says.. here she is, two coats. It has rained since the waxing... but I think it looks decent. I didn't use any Zaino or other expensive product. All I used was a generic off the shelf Carbauna Wax called KIT. Man it's hard to polish a black car....
Dough
Two Days After A 2 Coat Polishing...-dsc01492.jpg   Two Days After A 2 Coat Polishing...-dsc01498.jpg   Two Days After A 2 Coat Polishing...-dsc01499.jpg   Two Days After A 2 Coat Polishing...-polish1.jpg   Two Days After A 2 Coat Polishing...-polish2.jpg
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
Old 10-03-2004, 08:08 PM   #2 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
looks good
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 10-03-2004, 08:15 PM   #3 (permalink)
Tochenzo's Avatar
Tochenzo is an unknown quantity at this point
Send a message via AIM to Tochenzo
nice work
Tony
National Capital Chapter BMW CCA #367673
1998 Hellrot 328i
Tochenzo is offline   Reply With Quote
Old 10-03-2004, 09:58 PM   #4 (permalink)
Silver4evr's Avatar
Let us know how long the KIT wax lasts.
It would interesting to compare to the high end stuff.
You should try some acrylic polish. It lasts longer than carnuba.
Some people put acrylic on first, then carnuba.
Old 10-03-2004, 10:11 PM   #5 (permalink)
doughboyea's Avatar
[snapback]204276[/snapback]
Right... good, I'll post back in this post in a week? month? we'll see... but remeber, that's only two coats (put on in the same time period). It's not like some here whom have used dozens of layers (sometimes applying a new coat once a week). So two coats, applied ONCE, on Oct 1.....
Dough
Old 10-12-2004, 11:04 AM   #6 (permalink)
exceldetail's Avatar
exceldetail is an unknown quantity at this point
Keep in mind, if any wax you use has any type oc cleaner in it, layering is ill advised. Cleaners will remove the previous application.
Waxes without cleaners wont clean, or brighten the paint. You should really get into the habit of polishing prior to waxing or sealing.
Owner exceldetail.com
exceldetail is offline   Reply With Quote
Old 10-12-2004, 12:28 PM   #7 (permalink)
doughboyea's Avatar
[snapback]209898[/snapback]
Whatever man, All I did was just wash and wax with the KIT product which is suppose to enrich any old or faded paint color. Example, my mother's old '82 Mercedes 240D had a faded hood. The whole car was blue but the hood was nearly white. Using this shit made it match the rest of the car, perfectly.
Anyhow, it's been over a week and the car is still shinny, of course it's got road grime on it and dust, but another quick rinse would solve that. I believe the product was like $6 and it came with a sponge to apply the wax. Directions indicate that you should wash the car then apply a layer of the product to the body in sections with circular motions. Dab the sponge in water prior to applying wax to increase it's effectivness. I'll post a pic as soon as I can.
Dough
btw, exceldetail, reguarding ur concern to the layering process, I only mentioned that in the previous post as some on this forum utilize Zaino products on thier cars, though I don't see the need to dish out the $100+/- for it, they do use a particular method of layering thier cleaners, polishes and waxes.
Old 10-12-2004, 02:36 PM   #8 (permalink)
Originally posted by doughboyea+Oct 12 2004, 10:28 AM--><div class='quotetop'>QUOTE(doughboyea @ Oct 12 2004, 10:28 AM)</div><div class='quotemain'><!--QuoteBegin-exceldetail@Oct 12 2004, 12:04 PM
Dough
[snapback]209924[/snapback]
[/b][/quote]
Not a problem. Just sharing a wealth of experience with you folks. The cliche stands, "You get what you pay for"....But im like you in belief that i dont have a need for $100.00 items when 1/2 of that is more than sufficient. You spend thousand of dollars of these cars but are only willing to shell out $6.00 for protecting the finish? To each their own.....Next time you wish to apply products in a circular motion, dont ask yourself why you have swirl marks. All applications and product removal SHOULD be performed in straight lines.
Old 10-12-2004, 07:49 PM   #9 (permalink)
Silver4evr's Avatar
[snapback]209978[/snapback]
I don't see any swirl marks in his pics. His results belie your conclusion.
Old 10-12-2004, 09:09 PM   #10 (permalink)
Originally posted by Silver4evr+Oct 12 2004, 05:49 PM--><div class='quotetop'>QUOTE(Silver4evr @ Oct 12 2004, 05:49 PM)</div><div class='quotemain'><!--QuoteBegin-exceldetail@Oct 12 2004, 10:36 AM
[snapback]210132[/snapback]
[/b][/quote]
I never said he had them, but to avoid them, straight lines should be used. Personally, i wouldnt show pics of swirl marks in a pic even if there were some! Not a great selling point if your a detailer Silver.
See any difference in photos ? Dough, please take no offense, none intended.
Two Days After A 2 Coat Polishing...-roofreflection.jpg   Two Days After A 2 Coat Polishing...-demo.jpg
Old 10-12-2004, 09:37 PM   #11 (permalink)
doughboyea's Avatar
Difference is that you've got a better camera that I have.
If I were to apply in strips, i'd have scratch strips up and down the car... so it'd be the same either way. Besides, this is cheap, and it does protect. But of course, I could be wrong reguarding UV protection and all that. I'd love to get Zaino and spend a half day applying that on, getting a brilliant shine, but for now, using this stuff, while it lasts is alright by me. Looks good and is smooth, I'm sure if I clay it, it'd be ever better. My camera doesn't do it justice.
Dough
Old 10-12-2004, 11:24 PM   #12 (permalink)
Originally posted by doughboyea@Oct 12 2004, 07:37 PM
Difference is that you've got a better camera that I have.*
If I were to apply in strips, i'd have scratch strips up and down the car... so it'd be the same either way.* Besides, this is cheap, and it does protect.* But of course, I could be wrong reguarding UV protection and all that.* I'd love to get Zaino and spend a half day applying that on, getting a brilliant shine, but for now, using this stuff, while it lasts is alright by me.* Looks good and is smooth, I'm sure if I clay it, it'd be ever better.* My camera doesn't do it justice.
Dough
[snapback]210215[/snapback]
I didnt use Zaino....That was a Polymer product, I think it was Blackfire. My point is how often do you see swirls on dark cars vs. your so described "scratch strips"? Straight scratches are optically challenged by your eyes, whereas swirls are visible from ALL angles. try it, you'll like it. Your Beamer deserves better than Kit my friend. Thats alos the cheapest camera Fuji makes, cost a whopping $160.00 of QVC. Probably $120.00 at Best Buy !!
Old 10-13-2004, 02:49 PM   #13 (permalink)
doughboyea's Avatar
Well, here we go, one week later (actually almost 2 weeks). The original luster is still present, though a bit muted. The men that take care of the lawns here have raised up alot of dust, so my car is covered in it. I have not washed it or rewaxed it. And it hasn't rained. I've driven a few hundred miles since the last photos were posted.
Dough
Two Days After A 2 Coat Polishing...-dsc01573.jpg   Two Days After A 2 Coat Polishing...-dsc01574.jpg
Old 10-14-2004, 05:36 PM   #14 (permalink)
Heat and sun is Carnaubas worst enemy. Expect better results in cooler climates. You should get at least 4 weeks with that Kit stuff. Remember once the surface hits about 175 deg's, its about gone!
Old 10-14-2004, 10:56 PM   #15 (permalink)
doughboyea's Avatar
Ummm... ok exceldetail, for the money, I think it's good, and it's still shiny .
Dough
PS, it's fall in NJ... the temps don't go past 70F anymore, stays mainly in the mid 60's and down to the upper 40's at night.
Porting And Polishing.... nycbmw325is 3-Series (E36) 0 10-14-2004 03:43 PM
Can Milk Spoil the Clear Coat? CableGuy Wash & Detail 13 08-25-2004 12:44 PM
2001 Clear Coat Flaking Off bryno540 5-Series (E12,E28, E34, E39, E60) 6 08-01-2004 08:13 AM
