| You need to get a heat gun to slowly heat it, then it will pry right off. Don't use a blowtorch or some shit like that, it will burn the paint. Try a hairdryer on low if you don't have the heat gun. Your best off going to an autobody shop though. It will only take them 5 mins. Plus they will have the rubbing compound and finish glaze so there will be no traces. Good luck. Check mine
__________________ <img src='http://www.european-forums.com/forums/uploads/post-1-1119565837.jpg' border='0' alt='user posted image' /> |
