Saving $$$ on cleaning products - BMW Forum - BimmerWerkz.com
Old 02-09-2004, 12:51 PM   #1 (permalink)
Silver4evr's Avatar
After checking out various web sites for a quick detailing product and seeing that they cost about $50 to $75 a gallon I decided to see if I could home brew some decent stuff.
I took 8 oz of hot "soft" water, 5 drops of Meguier's clear coat body wash and a 3 caps of rubbing alcohol and slowly mixed in an old blender. I put the alcohol in so that it would evaporate more quickly.After it was thoroughly mixed I put it in a spray bottle. The alcohol also reduced the sudsing of the soap.
I used it on my mini-van as a test. It seemed to work fine. I used a very damp cloth to put it on (turning frequently so I didn't rub the dirt in)and then a dry soft cloth (turning frequently) to dry and polish. It also worked fine on glass. No streaks. Dried fast. Probably too much alcohol
I tried putting it on with a dry cloth but a damp cloth took less effort and wouldn't rub the dirt in to scratch the paint. I didn't notice any problems with the paint.
I made another batch of 20 oz of hot soft water, 2 drops of Meguiers and 1 cap of alcohol. I ran out of time so I'll test it later. I figure it cost me less than 3 cents to make this stuff. About 20 cents a gallon.
Will the alcohol remove carnuba wax or silicon polishes?
Has anyone ran across other home brew cleaning products that work? Any BMW chemists out there that have something better up their sleeve?
Note: This is not a recommendation to do this. Try at your own risk.
Old 02-09-2004, 01:06 PM   #2 (permalink)
Cavalier2123's Avatar
Cavalier2123 is an unknown quantity at this point
Send a message via AIM to Cavalier2123
Interesting stuff, let us know how it works. As far as alcohol removing carnuba, in my experience, no. I use that same wax and got careless and some got on my exterior black trim. I tried several different trim cleaners, degreasers, dish soaps, and alcohol. Peanut oil worked for me - try it for removing the wax...
"Make all checks payable to my ass" - W.A.K.
Cavalier2123 is offline   Reply With Quote
Old 02-09-2004, 03:10 PM   #3 (permalink)
Silver4evr's Avatar
My second batch worked much better.
I have a few more mixtures in mind to test.
I'll let you know.
Old 02-09-2004, 03:16 PM   #4 (permalink)
DrewHaHa328ci is an unknown quantity at this point
I just take clorox (powder) and mix it with hot water. Mind you, I put very little in. Is this bad for my paint at all? It seems to work fine w/o damaging anything but if it is bad for it someone tell me please. Thanks.
DrewHaHa328ci is offline   Reply With Quote
Old 02-09-2004, 07:31 PM   #5 (permalink)
RetroSpek's Avatar
RetroSpek is an unknown quantity at this point
clorox on your car ?
<a href='http://www.RetroSpek.com' target='_blank'>RetroSpek Website - Retro Vintage Everything</a>
RetroSpek is offline   Reply With Quote
Old 02-09-2004, 07:59 PM   #6 (permalink)
Silver4evr's Avatar
Maybe in small quantities bleach is okay. If you use it right after you wax, does the paint feel the same?
Old 02-10-2004, 12:16 PM   #7 (permalink)
Silver4evr's Avatar
I did another test of this batch and it's working fine. I cleaned my windows and when wiping them I could see the residue drying quickly just like the other 'quick detail' product I've seen.
My van also had a huge 4" blob of bird bowel extract on it and this stuff, with some gentle rubbing, did some great work.
I think I'll keep "home brewing" my own stuff and save a bunch of $$!
BTW, I used 20 oz of soft water because that's how much my spray bottle would hold.
Old 02-10-2004, 04:08 PM   #8 (permalink)
I would be cautious about putting any kind of powder, disolved or not, on your car. If any of the particles are not disolved completely, then it will scratch as you wash it.
&quot;Make all checks payable to my ass&quot; - W.A.K.
Old 02-23-2004, 11:01 AM   #9 (permalink)
Silver4evr's Avatar
You can use warm water to help disolve any powder type products you use.
I've also seen a thick plastic mesh that goes in your wash bucket about 2 inches from the bottom, keeping your wash mitt/cloth/sponge from picking up any large/heavy dirt particles resting on the bottom of your bucket.
On another forum, someone made a this type of product by cutting a piece of plastic purchased at Home Depot and setting it in their bucket.
What detail products do you use? Silver4evr Wash & Detail 2 05-10-2004 05:48 PM
most cleaning products arent so good sakuramboo Wash & Detail 2 12-09-2003 03:16 PM
Griot's products??? AZ325Ci Wash & Detail 8 08-12-2003 05:40 PM
