removing rust - BMW Forum - BimmerWerkz.com
Old 07-04-2003, 02:46 AM   #1 (permalink)
Car: E30
bimmergurl10 is an unknown quantity at this point
Send a message via AIM to bimmergurl10 Send a message via MSN to bimmergurl10
Anyone have any good steps to remove small rust spots? I was going to sand it and then use a touch up pen, but i want to look at my options before i do this.
<span style='font-size:8pt;line-height:100%'>1987 325iS
</span>
bimmergurl10 is offline   Reply With Quote
Old 07-04-2003, 04:02 AM   #2 (permalink)
CMGO is an unknown quantity at this point
wet sand it. dont just sand it with dry paper. use fine grit to remove the rust then ultra fine to smooth it out. then use a primer then the touch up paint. sand again with ultra fine and you should be golden.
Im no body shop guy, but Ive heard this is a good practice.
Best of luck.
<img src='http://www.azkphoto.com/choices.jpg' border='0' alt='user posted image' />
05 WRX STi
-04 H2
--98 M3-SOLD &quot; I miss you dearly&quot;
---87 Porsche 944S
----94 Toyota 4x4
-----82 Yamaha XJ750 Maxim
CMGO is offline   Reply With Quote
Old 07-04-2003, 06:30 AM   #3 (permalink)
SpeedsterBMW
Guest
Posts: n/a
normal sand paper is the worst, it is not a unified grit, (the grit is the AVERAGE size of the particles, if your going to wet sand, get Meguiars Uni-Grit sand paper, and then buff it out with a bugger/polisher (machine)
Old 07-26-2003, 12:24 PM   #4 (permalink)
morph's Avatar
morph is an unknown quantity at this point
Send a message via AIM to morph
you can get touch up paint at your dealership. it does a great job of making little spots disappear.
<img src='http://home.earthlink.net/~thefurthestpoint/bimmer.jpg' border='0' alt='user posted image' />
morph is offline   Reply With Quote
Old 07-26-2003, 01:10 PM   #5 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Retard. It's sand paper, it's job is to sand stuff down. Why in the Heck would it matter if the sand paper wasn't unified. Freaking cum bubble.
Anyway - make sure it's only rust and not the begining of rot. Definitely use some primer after sanding on the rust and before painting. There are also products out there that stop rust for getting worse (essentially they reverse the rust process to a certain degree).
May the force be with you.
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 07-26-2003, 02:05 PM   #6 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
my friend used i think 409 and a brush. worked pretty well.
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Rust Prevention mech9T8 3-Series (E36) 6 09-21-2010 09:33 AM
Rust Removal Advice Needed!!! dagli 3-Series (E21, E30) 8 11-12-2005 05:27 PM
Removing original stereo Mfaleni 3-Series (E46, E90) 1 11-08-2005 06:18 PM
Removing parking brake cables 325i_family 3-Series (E36) 3 09-18-2005 06:28 PM
540 Shopping... How Common Is Body Rust In '95s? primarycolorman 5-Series (E12,E28, E34, E39, E60) 7 10-15-2004 04:50 AM
