Removing Pin Stripping - BMW Forum - BimmerWerkz.com
Old 03-30-2005, 09:42 PM   #1 (permalink)
phathaway is an unknown quantity at this point
Reading through the forums and looking at countless other BMWs, I have realized that my car is the only one I've seen with pin stripping. I am not a big fan of this, and was wondering how hard it is to remove, and what kind of residue is left behind and what it takes to clean it off. I was also wondering about removing the 325i emblem on the back, although that is not nearly as gay looking, and kinda nice sometimes.
phathaway is offline   Reply With Quote
Old 04-04-2005, 03:10 PM   #2 (permalink)
TWKTCC is an unknown quantity at this point
If the pinstripe is a vinyl add on then there is a rubber like wheel attachment you can buy at an autobody supply shop that goes onto a drill. It will take off the stripe without damaging the paint. If it is painted on it is very difficult to remove without damaging the paint under/ around the stripe.
TWKTCC is offline   Reply With Quote
Old 04-04-2005, 03:41 PM   #3 (permalink)
'89 635 csi's Avatar
'89 635 csi is an unknown quantity at this point
If it's vinyl use a heat gun (blow dryer).
Dave G.
'89 635csi
'86 528e - Sold
'84 528e - Soon to be 533i
'96 Jeep Cherokee 4WD
OO=[][]=OO
'89 635 csi is offline   Reply With Quote
Old 04-06-2005, 05:36 PM   #4 (permalink)
hitman2045 is an unknown quantity at this point
Send a message via AIM to hitman2045
if its vinyl u can use oven cleaner u just have to re wax the spot no harm to your paint believe it or not
first try picking at one of the ends w/your finger nail that worked for me , just take your time and one it starts to come off keep you hands close to the car ot the pin striping will snap/break and its like starting a rol of tape
hitman2045 is offline   Reply With Quote
Old 04-20-2005, 01:06 PM   #5 (permalink)
Red_Rocket's Avatar
Location: Coeur D' Alene, ID : Tuscaloosa, AL : Atlanta, GA
Car: BMW 325
Red_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really nice
Send a message via AIM to Red_Rocket
I removed the pin stripe on mine with some plastic scrapers desigined to remove stuff like that.
Now the pin strip has been on the car since 87 so it left a gluey residue behind on most spots.
I used a paint thinner to remove the glue, BEFORE YOU USE THE THINNER, test it on your paint. Some paint will rub off into the rag you use with the thinner, but not a noticable amount.
Finish up with a hard waxing on all removed spots, if your car is old and has been baking in the sun for a few years, there might be some color difference underneath the stripes to the color everywhere else.
But all in all, it makes your car look sportyer.
Good luck
Red_Rocket is offline   Reply With Quote
Old 04-22-2005, 02:07 PM   #6 (permalink)
Punchit is an unknown quantity at this point
A little 3M adhesive remover and a blow dryer takes it right off. Just make sure you wipe up the reamaing adhesive remover. It will take off some of your wax so just make sure you put some wax on it after.
<a href='http://www.detailedimage.com' target='_blank'>www.detailedimage.com</a> - high end detailing products
Punchit is offline   Reply With Quote
Old 03-12-2009, 01:55 AM   #7 (permalink)
325i05's Avatar
325i05 is on a distinguished road
I used Meguiars 83 and a PC. Worked great on mine. No telltale of any stripes.
325i05 is offline   Reply With Quote
Old 03-19-2009, 08:23 AM   #8 (permalink)
exceldetail's Avatar
exceldetail is an unknown quantity at this point
That would have been my rec also......
Owner exceldetail.com
exceldetail is offline   Reply With Quote
Removing original stereo Mfaleni 3-Series (E46, E90) 1 11-08-2005 06:18 PM
Removing parking brake cables 325i_family 3-Series (E36) 3 09-18-2005 06:28 PM
removing head liner ? j123crx 3-Series (E21, E30) 7 09-15-2005 08:10 PM
Removing pin stripping dblmikeusa1 3-Series (E36) 0 09-04-2004 07:54 PM
