Oxidation - BMW Forum - BimmerWerkz.com
Old 09-20-2003, 10:58 AM   #1 (permalink)
dpineda is an unknown quantity at this point
[FONT=Arial][SIZE=1] I'm new here. Stumbeled upon this form looking for ways to get rid of the oxidation on my E30. I'm assuming the best way would be to get an orbital buffer and a lot of rubbing compound then follow up with a wax? What do you all think would be the best way to remove this oxidation. I can't stand having to see my bimmer looking like this....
dpineda is offline   Reply With Quote
Old 09-20-2003, 03:38 PM   #2 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
Welcome to the forums!! B)
You need a clay bar to get rid of the oxidation then a good quality wax afterwards..maintenance is the key!!
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 09-22-2003, 09:53 AM   #3 (permalink)
The Limey is an unknown quantity at this point
forgive my, ignorance but whats a clay bar?
The Limey is offline   Reply With Quote
Old 09-24-2003, 08:55 PM   #4 (permalink)
Ski
Ski's Avatar
http://www.mothers.com/detailguide/tip29.html
Good info..
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Old 11-20-2003, 02:34 PM   #5 (permalink)
morph's Avatar
morph is an unknown quantity at this point
Send a message via AIM to morph
i hear that a good rubbing compound and some standard hard work can make the difference. i have heard horror stories of buffers...i am debating buying one myself. i don't have swirlmarks, but i do have a few scratches i am going to try and get rid of with the rubbing compound and some TLC. good luck.
<img src='http://home.earthlink.net/~thefurthestpoint/bimmer.jpg' border='0' alt='user posted image' />
morph is offline   Reply With Quote
Old 11-21-2003, 05:49 PM   #6 (permalink)
mobtek520i's Avatar
mobtek520i is an unknown quantity at this point
you'll be amazed at the amount of unseen shite the clay bar will get off your car man, make sure you use the spray that comes with it.
cheers mob
- Spank my muffin!
mobtek520i is offline   Reply With Quote
Old 11-22-2003, 01:31 AM   #7 (permalink)
the///man is an unknown quantity at this point
buffers do leave quite a bit of swirlies on your car, elbowgreese is the way to go IMO
the///man is offline   Reply With Quote
Old 12-09-2003, 03:24 PM   #8 (permalink)
timsev is an unknown quantity at this point
no,no,no. you must get a RANDOM ORBITAL buffer if you are a noobie buffer. they won't leave swirl marks if done correctly, ask someone experienced to help. you must use several compounds and wax. that's the only way to get rid of bad oxidation.
timsev is offline   Reply With Quote
Oxidation cardio Wash & Detail 7 10-07-2003 07:01 PM
