i think there was a post about this, but i wasnt able to find it, i want my engine/engine bay to really shine, the esy on top stuff is easy to clean and shiny, but theres still dirt and stuff in other places that are a little hard to get to, on my contour i would just spray it with degreaser everywhere, little elbow grease, and hose it down, but then again, it wasnt a bimmer...wut do u guys suggest?
__________________ <img src="http://img514.imageshack.us/img514/3500/sig21zo.gif">
1995 M3
1994 Supra TT 6SPD (Gone)
1994 Supra TT a few goodies
2003 Infiniti FX
You dont need class to go fast, you need balls
GUNK spray from any auto store, used it on my engine, when i redid my coolant system, worked like a champ romoved all grease and crap, and didnt damage anything
Method:
Spray on
Scrub area
Spray off with water (yes just use water, Everything will be fine)
i still havent gotten my engine bay cleam like i wanted, i really am too scared to hose it down, i asked before, but didnt get a solid answer, wut should i cover up before hosing down my engine
I sprayed acetone all over the engine bay and let it sit for about 10-20 seconds before spraying it off with a pressure washer. No harm done, just make sure all fuses and bare wires are not visible. You should have no problem with water, as there is always moisture in the engine bay when it rains - therefore the only thing you really have to worry about is erosion with a high molar concentrate of cleaner.
yikes , acetone will eat into and dull plastic , i have pressure washed more eng then i can count , 1 out of 10 has produced a misfire from water on the ign. system and thats cured by spraying wd-40 on it and thats all ( wd-40 stands for water displacement -40th try ) if you do it at a car wash it can be a day of waiting for it to dry then drive away , if you do it at home then just wait a few hours before starting it , you should be fine , i have pressure washed my z3 with out any problems .
