Cleaning in the dark - BMW Forum - BimmerWerkz.com
Old 01-08-2006, 04:18 PM   #1 (permalink)
BMW Kraft's Avatar
BMW Kraft is on a distinguished road
What's the best kind of light to use to wash a car?
I just had a 22 hour road trip (both ways) and it's dirtier than the war in the middle east. Only problem is I work till 5:30 everyday and by the time I get back home its a bit dark.
Question is what would be the best lights to use so that I will not miss any spots (a bit of a perfectionist )?
Thanks ahead of time.
'92 318i - Bilstein Sport Tuned Suspension, Performance Tuned Chip
///BMW=-
BMW Kraft is offline   Reply With Quote
Old 01-10-2006, 05:13 PM   #2 (permalink)
BMW Kraft's Avatar
ok.... so everyone uses the sunshine...
///BMW=-
Old 01-11-2006, 12:53 PM   #3 (permalink)
BMW Kraft's Avatar
success!
i used a spot light, house lights, garage lights, and a flash light!
///BMW=-
Old 01-11-2006, 02:49 PM   #4 (permalink)
red330Iperfpkg's Avatar
Car: 2003 330i ZHP
red330Iperfpkg is just really nicered330Iperfpkg is just really nicered330Iperfpkg is just really nicered330Iperfpkg is just really nice
Send a message via AIM to red330Iperfpkg
i always wash my car at night...just turn on the outside lights....i do this so it wont dry and spot
but thats just me
sig done by SpeedInfusion
2001 740i sport
2003 330i ZHP
2003 M5
2005 A4 1.8T
2006 750Li sport
red330Iperfpkg is offline   Reply With Quote
Old 02-06-2006, 12:28 AM   #5 (permalink)
Silver4evr's Avatar
I use a couple of 500 watt work lights (found at Home Depot), a 75 watt yellow spot light and a couple of 75 watt white spot lights that are on my house. I'm sure the work lights would be fine by themselves. You may have to move them occaisionally to get the right lighting angle.
Be sure not to get any water spray on them!
I don't spray the water from my hose anymore, I just let the water run straight and let the water sheet off before and after washing.
Old 03-29-2006, 04:57 AM   #6 (permalink)
mehumming's Avatar
mehumming is on a distinguished road
Send a message via AIM to mehumming Send a message via Yahoo to mehumming
Lightbulb hps
Well i have tried high pressure sodium lamps or metal halide, The light isn't natural but gives you plenty of area to work with.
every bump, seam, chip, scratch shows up under these light i have found their bloody power full and rather economical to run ..
The only down turns when using these lights they are very heavy due to the transformer and large area reflectors make them hard to move around..
Four lights positioned around the vehicle should give a fast and overall lightened area for washing and drying .
Be careful with temporary lighting when using extension leads, make sure there is a safety device connected to you leads to minimize the risk of electrocution,
keep all leads raised from the ground.
better than that have some lights installed on post around the area in which you designate your wash zone . to easy very convenient if you cant get home early enough and wash during the evening..
try blind folding your self and then wash your car, rinse and dry see how you did no needs for light :lol:
mehumming is offline   Reply With Quote
Cleaning MAF sensor info! LOS 5-Series (E12,E28, E34, E39, E60) 3 01-03-2006 07:25 PM
Cleaning Wheels moe19x Wash & Detail 5 07-16-2005 11:56 AM
Need Instructions On Cleaning Icv BMW-ATI 3-Series (E36) 0 04-11-2005 09:37 AM
cleaning schneider252 Wash & Detail 3 05-23-2004 05:22 PM
