Claying - BMW Forum - BimmerWerkz.com
Old 01-02-2005, 10:18 AM   #1 (permalink)
JWK
JWK is an unknown quantity at this point
I have heard this term used before, but what is it? Do you actually use clay on a car?
Please advise, I am curious.
Thanks.
JWK is offline   Reply With Quote
Old 01-02-2005, 11:49 AM   #2 (permalink)
MaThGr82's Avatar
MaThGr82 is an unknown quantity at this point
Yes, it is actually a piece of clay manufactured by many companies. I use a brand called Clay Magic.
Basically what it does is take off any particles stuck to your paint. My truck and car for instance, get a ton of oil specks on the underbody because my in-laws live out in the country where they oil the roads.
So basically you can clay one of two ways. The first few times you clay a car, do it after you wash the vehcile and completely dry it. Use the lubricant that will come with the clay. After the first few times, you can actually just clay the vehilce while you are washing it. I typically will wash the car and rinse it off, then clay it with the water. You just have to make sure there is enough water for the clay to glide over the surface.
Oh yeah, BTW, if you ever drop the clay, you have to throw it away because of all the dirt it will pick up will destroy your paint. That is actually why I like to rip the piece of clay into 3 or 4 smaller pieces. So if I drop it, I didn't just waste $10.
<img src='http://img.photobucket.com/albums/v296/MaThGr82/BMW%20325Ci/5d2c4361.jpg' border='0' alt='user posted image' />
MaThGr82 is offline   Reply With Quote
Old 01-02-2005, 12:29 PM   #3 (permalink)
mech9T8's Avatar
mech9T8 is an unknown quantity at this point
I've used the clay many times and it works really well.
If you run your hand over the hood of your car it will feel kinda rough (depending on how old your car is). This is a build up of contaminants over time. After you finish with the clay it will feel as smooth as glass.
The first time you use it you'll think you are scratching your paint, but believe me, you aren't. Just make sure you use plenty of lubricant and you keep folding the clay over (just read the instructions).
Follow up with some wax and you are good to go.
I use Mothers.
<img src='http://www.geocities.com/royb9t8/MY_BMW_2.jpg' border='0' alt='user posted image' />
<span style='color:blue'>My ass may be dumb, but I ain't no dumb ass!</span>
mech9T8 is offline   Reply With Quote
Old 01-02-2005, 01:11 PM   #4 (permalink)
exceldetail's Avatar
exceldetail is an unknown quantity at this point
[B]As I wrote for other forums.....
No complete detail is complete unless you have "clayed" your vehicles surface. Kind of a strange name for a product, but I assure you its completely safe when used as directed. It can be rather intimidating if you have never used before, but once you have, you’ll wonder why you waited so long. Clay is designed to pull contaminants away or simply sheer them from your paint surface, safely, and this is accomplished with ease.
So what equipment or materials is needed? There’s no equipment needed at all! All you need is clay, and a lubricant, and a micro fiber towel for wiping upon completion. Now you can skip the towel if you elect to clay while washing.
There are many brands of clay available, and at least two are usually available at your local auto paint supply store or Automotive parts store (Kragen, Pep Boys). Meguiars makes a new version, better than its preceding version, Mothers makes a nice kit, comes with the clay, a lubricant (Showtime QD), and a small sample of Pre Wax Cleaner. The original Clay Magic I believe still comes with a lubricant as well. Make sure you buy or are using “Fine grade” in the beginning stages.
So lets get started !
Lets assume, it’s the beginning of summer, and you want your ride looking the ultimate! You begin with your normal wash routine (see Proper washing techniques), you’ve removed any tar, gum, and assorted crap stuck to the lower panels with a citrus cleaner or tar/adhesive remover (3M comes to mind). Now you have dried the surfaces with a waffle weave drying towel, and "she" looks good, you rub your hand along the top of the hood, and you feel what seems like specs of sand (If you think it feels good at this point, put your hand in a sandwich baggy)..... Close analysis, its actually tiny bits of metal (Brake linings, rail dust), or just normal industrial fallout. Its inescapable, pollutants happen to everyone, and the reason we need to remove these pollutants is, metal contributes to rust, and once rust starts, it’s usually not good! Not to mention physical appearance anyway.
Make sure your working in a shaded area, on a cool surface. Once you get started, the whole process can be completed in about ˝ hr. Lets start with the hood. Unwrap your clay product, and take about 1/3 to ˝ of it in the palm of your hand. Place the other portion back in the wrapper it came in, you may need this in case you drop the 1st half. If you do drop it, discard it. Spray the lubricant on about ˝ to 1/3 of the surface, just as you would while quick detailing it. Take the clay in your hand and knead it until its somewhat soft. Mold to about the size of a small pancake, and place at your fingertips for easy control. Gently place the clay on the surface and glide it back in a front to back motion (grill to window). Use about 10-12 inch passes and overlap each pass. Fold the clay after each area has been cleaned. You will feel some resistance at first, but with passing motions, you’ll be able to tell the clay is removing pollutants! If you feel too much resistance, your either not using enough lubricant or your surface is REAL dirty. A good way to tell you’re not using enough lube or if your surface is too warm, is the clay is leaving product on the surface. This can be removed, with a micro fiber towel. After each area has been clayed, wipe and buff dry with a micro fiber towel.
Clay will remove a portion of wax or sealant protection, so you should follow up with polishing and sealing/waxing. Clay is not a polish! It will remove contaminants, small areas of road tar, road paint, over spray, fallout, and light oxidation. Any areas larger than an eraser tip should be cleaned with a cleaner prior to using clay, otherwise you will end up polluting your clay for future use. You should be able to clay your surface half a dozen times, depending on the quantity of contaminants.
If anyone has additional comments or concerns, feel free to post, or PM me !
Owner exceldetail.com
exceldetail is offline   Reply With Quote
Old 01-02-2005, 09:52 PM   #5 (permalink)
JWK
Thanks for the info and advice. Now the big question, where can I get some clay bars and lubricant? We don't have a PEP Boys where I live. Any other suggestions?
Thanks again.
Old 01-02-2005, 10:06 PM   #6 (permalink)
MaThGr82's Avatar
http://www.autopia-carcare.com/detailingclay.html
Old 01-02-2005, 11:26 PM   #7 (permalink)
thesoprano's Avatar
thesoprano is an unknown quantity at this point
Send a message via AIM to thesoprano
I clayed last week. Very labor intensive and can be deceiving on a certain levels. But once you are completely finished, the results are undeniable. I used the Mothers clay kit from autogeek.net.
<img src='http://www.bartspace.com/mtech.jpg' border='0' alt='user posted image' />
<span style='color:red'>RIP 1992 E30 325i Convertible M Technic</span>
<span style='color:blue'>1996 E36 328iC</span>
thesoprano is offline   Reply With Quote
Old 01-04-2005, 12:58 AM   #8 (permalink)
Power Shifting
Cruzin 323is's Avatar
remember: clay strips wax.. so u have to wax it when your done!! claying it just to prep!
-SOLD..
R.I.P Fast 6
After Claying and some Sick ones... 56K be scared! 97alpineM3 Picture Showroom 12 11-12-2005 07:19 PM
Mothers Claying Kit mrimark Wash & Detail 7 03-12-2005 12:39 AM
Claying And Waxing JWK Wash & Detail 4 02-06-2005 11:37 AM
Best Wax After Claying Car mrimark Wash & Detail 10 01-04-2005 01:05 AM
Claying BLACKBMW Wash & Detail 8 11-10-2004 01:32 PM
